#26 |
![]() Join Date: Sep 2016
Re: For better or worse, shes in my driveway.
The plan is baby steps. I want to enjoy it while also getting to choose projects as I go. I'm ok with driving around a junker for a while of the brakes and tranny runs. What I'm running into at the moment is just trying to get the engine back into operable condition and give the interior a good scrubbing so I'm not eating dirt while driving down the road. I have ordered a replacement driver door window because it's broken. If I can get those things done over winter, I can then tackle some of the surface rust areas where I can just grind and primer for now to stop the slow destruction of the metal.
#27 | |
I decided to grab a 12v battery and plug it in based on a few items in the engine bay seeming like it was for a 12v. Here is where the unexpected issues start. So nothing happened when I plugged the battery in. I found the grounding strap to the starter had been chewed off by rats and was just hanging there. I then found a wire to the alternator that had been chewed off and was hanging under the engine bay. Both headlights have had their wires chewed off...it's a treasure trove of fun lol On top of all that, today I noticed fluid on the driveway. Looks like the radiator is leaking but I haven't pulled the front grill off to see if it's a hose leaking or the radiator itself. All part of the adventure I suppose ![]() |
#28 |
Post Whore
![]() ![]() Join Date: May 2015
Gigimax...I wouldn't hook that battery up again until you trace out all the wiring..you've already found rat damage where you can see it imagine all the damage you can't see...be a good way to destroy what's left of your harness if there's a short somewhere..
#29 |
ordered an electrical guide to help me out with it. I don't see any issues under the dash, so it looks like I just have to go through the engine bay
#30 |
Make sure the BRAKES WORK first!
I would take out the tail light bulb and check it for 6 or 12VDC
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#31 |
![]() Join Date: Aug 2011
awesome project. have fun with it/ Subscribed/
Pat 1949 unmolested Indy Farm Deluxe AD 1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544 |
#32 | |
Got the emergency brake unstuck but have no idea if it even works since it was set when we rolled the truck on and off the trailer for transport with the wheels spinning freely. |
