Old 11-13-2016, 09:51 PM   #26
Advanced Design
Advanced Design's Avatar
Re: Bag'd 53 stock frame,1pc driveshaft,2pc? Help
That's a good solution. Why is the shaft right in front of the pinion reduced in size?
Advanced Design is offline   Reply With Quote
Old 11-14-2016, 12:19 AM   #27
Fiftee3
Fiftee3's Avatar
That shaft on the pinion will pull out when the truck drops. It has a grease zirk on it also.
Because the bearing is bolted to the front shaft, It will not pull out of the trans at all. All movement will happen from the rear.
"All the best, Phil"
My 53 IFS air bagged Upgrade Here
One of my threads for this build...
http://67-72chevytrucks.com/vboard/s...12#post7662512
Fiftee3 is offline   Reply With Quote
