Old 12-19-2016, 07:46 PM   #26
tommy3horse
tommy3horse's Avatar
Re: Is my 350 on the outs?
Update; the weather broke to the point where I could move things around and pull the expired engine today. 30 degrees is way better than the single digits over the weekend round here. Gonna clean things up a bit and ready things for the crate to go in on Thursday.
1972 GMC C1500 350/350
1965 Mustang 2+2 289 4spd, show-car
1965 Mustang Coupe 289 4spd, stoplight racer
1/2 dozen Wheelhorse Tractors
tommy3horse is offline   Reply With Quote
Old 12-31-2016, 09:57 PM   #27
tommy3horse
Had the time this week to put everything back on the motor. Today, I got the engine oil system primed, fitted the dipstick and installed the intake and valve covers. Tomorrow it goes back in the truck, and if all goes well I will attempt to bring it to life. Looks decent to boot
Old 01-23-2017, 06:56 PM   #28
tommy3horse
Alrighty, I finally got everything bolted up and worked out the kinks, like a vacuum leak and leaking heater core. Put a decent initial tune on it and have logged a whopping 170 miles so far. No leaks on the motor, but the p steering hose is dripping a bit at the pump and probably needs replaced. Runs really well!
Tom
Old 01-23-2017, 08:11 PM   #29
hamjet
hamjet's Avatar
Great news! glad everything turned out OK. it looks great too...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 01-27-2017, 06:43 PM   #30
tommy3horse
UPDATE:
Have driven a very easy 200 miles, runs great, but rear main appears to be leaking. Anyone know the process for getting this repair started via the warranty?
Thanks,
Tom
Old 01-27-2017, 08:21 PM   #31
hamjet
hamjet's Avatar
check a few things first. maybe leaking at the oil pressure sending unit behind the intake, the rear intake gasket, or in back of the valve cover gasket, could appear to be a rear main seal. retorque the pan gasket also..
Thanks, Joe..
Old 01-29-2017, 11:12 AM   #32
tommy3horse
Thanks Hamjet, it's Sunday and I have the time today to check those things...
T
Old 02-01-2017, 06:55 PM   #33
tommy3horse
Hello,
Joe, you were on it! I pulled the converter/flywheel cover and it was dry as was the back end of the crank area. I found the valve cover bolts very loose and a trail of motor oil which must have blown away from the block and landed on the trans cooler lines, fill tube inspection cover on the outside.
I watched my old 350 drip outta the rear main and (everywhere else)for 2 years and it looked very similar.
Thanks again,
Tom
BTW the old motor has a steel crank and KB pistons, cylinders look to be .020 over bored. Wonder what's up with that, and it has 2 bolt mains...?
Old 02-01-2017, 07:42 PM   #34
hamjet
hamjet's Avatar
Very good, you must be a happy camper now. on the older engine, there's nothing wrong with 2 bolt mains. they're good for 7000 RPMs, I've never seen the crank rip out the bottom end from people using 2 bolt mains in moderately built HP engines...
Thanks, Joe..
Old 02-01-2017, 07:55 PM   #35
tommy3horse
A steel crank tho...?
