Old 05-15-2020, 09:02 PM   #26
ace347
ace347's Avatar
Re: LED Flasher that works with 67-72 Chevy Trucks
Originally Posted by Robznob11 View Post
Here are some things I have had reported back from customers . Many say that the polarity is opposite between the turns and the flashers. Meaning you need 2 flashers and only one needs the polarity reversed. Usually the turn side. I have included a pic from a customer and fellow board member Mac’s Garage on his solution. He has found a Napa brand flasher no ground strap that works and blinks proper speed. And also an adapter to reverse the one flasher.
I'll check these out. I'm just not sure if I have an issue elsewhere. One thing that makes me wonder is that my turn signal lights on the dash don't seem to be working. The gauge cluster circuit board is the all original. When I replaced all the dash lights with Leds I looked at the board and didn't see any issues. Had to replace a few sockets aswell.
ace347 is offline   Reply With Quote
Old 05-16-2020, 09:43 AM   #27
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: LED Flasher that works with 67-72 Chevy Trucks
Ok, this maybe some of the trouble.
Well it's all new from LMC. LEDs, fuse box, everything.
LMC has had a bunch of wiring issues with the relay kits for the head lights, there are many post on here about the wires being crossed up in the kits. I would be inspecting these parts good.
I would be looking at the half moon connector under the dash. I have had trouble before with them not matting up good and the pins coming out of the plastic holders when trying to connect them. All your turn signals and brake lights go through this connection. Just take your time. Check each wire with a test light and find where the juice stops.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-16-2020, 10:52 PM   #28
ace347
ace347's Avatar
Now that you mention that. I had to repin that particular connector with the original plastic to get that to work. Took me a while to figure out what was going on. I never used a test light on it though. Might look into that next.
Old 01-03-2021, 09:04 AM   #29
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Ah, I did not realize we needed two flashers - which is why my Hazards Flash Fast (Hyper Flash)! Though now looking at the fusebox, I see the flasher can at the top! Doh!
Thanks for this thread!
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
