#26 | |
![]() Join Date: Nov 2001
Re: WTB... 327 Block
But that shows me some interesting info. It shows a V 1104 YH with a Block Cast Date K 3 6 which tells me the block was cast on Nov 3rd and assembled Nov 4th So, maybe I should be looking for a much closer to Dec 20th 1966 cast date Hmmmmmmm... very interesting that the cast date and assembly date are that close. So... I am revising my search... I am now looking for a Mid-Dec cast date block. Ideal find would be a 3892657 block cast date of L-10-6 to L-19-6 Jmader, thank you so much for finding me that info.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
#27 |
![]() Join Date: Aug 2013
I think these things were pretty random. The 327 I found for my truck has a casting date of E-4-6 but the engine pad is stamped F0505YM (the casting #3858174 was not used in 1966 vehicles) so this block sat around for over a year before it was used in a truck. You just never know
1949 Chevy 3100 Five Window 1964 Chevy C10 Lambrecht Auction project 1967 Chevy SWB K10 1967 GMC K15 Project Build thread- http://67-72chevytrucks.com/vboard/s...72#post6502772 1968 Chevy Anniversary K10 1991 K5 4" Lift 35's (the wife's toy) |
#28 |
I agree, I think they were pretty random.
But, If I can stumble across a 3892657 block with a cast date of between L-10-6 to L-19-6 I think it would be a no brainer in not having to explain the huge date difference.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 01-09-2015 at 01:56 PM. |
#29 |
I am still looking for a 3892657 block cast date of L-10-6 to L-19-6
#30 | |
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#31 | |
could very well have a casting date as late as L 19 6 and it is probably a 3892657 casting number. If we locate an original engine on or very closely before that assembly date it will then be a decision if its "close enough" or a reference for the casting numbers and dates of all the major components as would have been used on your vehicle to futher narrow the search.
#32 |
What's your source that says the YH was used in '66 trucks? I could never find anywhere that said that. You're probably right though that would explain the big date gap.
#33 |
This is from the 46-72 Chevrolet series 10 20 30 truck parts manual dated 5/79.
#34 |
Oh sorry my block is a YM suffix not YH. I don't see the YM in that list. Do you have any more info on the YM?
#35 | |
and a casting date of L 10 6 to L 19 6 (rear pass side of block)
#36 | |
I was kind of thinking of getting a block that "could have been correct" simply due to casting date. Of coarse... ideally a V1220YH would be awesome. I guess I was just not dreaming that big. And, based on the sheet above... How did my 1967 1/2ton have a YH code?
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 01-13-2015 at 05:05 PM. |
#37 |
ttt
I am still looking for a 327 stamped V1220YH (front pass side in front of cyl head) or a 3892657 block cast date of L-10-6 to L-19-6
