Old 12-27-2016, 09:07 AM   #26
Stickman
Stickman's Avatar
Re: 1972 C-10 - Project NVR-ENUF
Good Morning
Awesome build, frame will be easy on the eye when you get it back from powdercoat. Curios as to why you went with the No Limit rear trailing arm as opposed to PB etc ? I'm seriously considering purchasing his set up and we all know Rob knows how to make one handle for sure and it looks like a great product.
Kirk
Stickman is offline   Reply With Quote
Old 12-27-2016, 09:56 AM   #27
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
this is going to be one smokin' hot chick!
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline   Reply With Quote
Old 12-27-2016, 10:49 AM   #28
SMKN TA 95
Originally Posted by Stickman View Post
Good Morning
Kirk
Kirk, thank you for the comments! I went with the No Limit rear setup due to shock placement, longer stroke shocks, and just looked like a very nice setup. I purchased the PB inner stiffener AFTER I bought Robs kit, so I made his kit work with the PB mounts. I'm having stainless spacers/shims/sleeves made to locate his trailing arm bushings in the wider PB/stock type width mount.
Im anxiously awaiting getting behind the wheel of this thing
-1998 Formula WS6 1LE- LSX 427
4.58 @ 162 mph, 1.12 60'
2017 Silverado 3500 High Country DRW DMAX, 20" Fuel Wheels
1972 Chevrolet C10 Cheyenne - SOLD
RaceWire Solutions
SMKN TA 95 is offline   Reply With Quote
Old 12-27-2016, 12:16 PM   #29
Trackman101
Trackman101's Avatar
.... using some serious parts! Amesome
Obviously judging by your numbers you know what your doing.
Trackman101 is offline   Reply With Quote
Old 01-27-2017, 11:12 AM   #30
SMKN TA 95
Time for some more updates...
Frame is back from powder coat now, and assembly has started. I just recently picked up NY new Strange Center section too. I went with the Strange HD Pro aluminum Center, with a 3.70 gear, 35 spline axles with an HD 35 spline posi, Billet front bearing support and Billet yoke.
Onto the pictures...
RaceWire Solutions
Old 01-27-2017, 11:16 AM   #31
SMKN TA 95
A few more of the custom spacers we made to use the new No Limit Trailing Arm setup with a Porterbuilt Inner stiffener.
RaceWire Solutions
Old 01-27-2017, 12:29 PM   #32
bigdog55
bigdog55's Avatar
I like the look
Brian
bigdog55 is offline   Reply With Quote
Old 01-27-2017, 01:36 PM   #33
Dustmaker65
Dustmaker65's Avatar
Very nice! Think I will tag along to see it get finished too!
Who is doing your paint?
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 01-27-2017, 04:06 PM   #34
Pinky6872
Looking good, Nice work!
My Dropmember Equipped Build
Instagram @chrispinkosky
Pinky6872 is offline   Reply With Quote
Old 01-27-2017, 09:54 PM   #35
GR8-68
GR8-68's Avatar
This is going to be one bad azz ride
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 01-28-2017, 10:43 AM   #36
Advanced Design
Advanced Design's Avatar
Love an awesome looking chassis...very nice!
Advanced Design is offline   Reply With Quote
Old 01-28-2017, 02:43 PM   #37
BossHogg69
motor exploder
BossHogg69's Avatar
Very nice work and parts going into this! Kudos to you for keeping it a long bed.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 02-17-2017, 02:30 PM   #38
SMKN TA 95
And we have more pictures!
Engine is installed, brake lines done front to rear with all 3AN fittings and line, All brakes and rearend officially done, gas tank in, supply and return fuel lines done and mounted to frame with billet clips and spacers etc. LOTS of work has been going on for sure.
RaceWire Solutions
Old 02-17-2017, 04:43 PM   #39
RRR18
RRR18's Avatar
Bad as hell.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 02-17-2017, 05:14 PM   #40
MMcMasters
MMcMasters's Avatar
Killer build!!
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 02-18-2017, 10:59 AM   #41
Stickman
Stickman's Avatar
Looking Good
Old 02-09-2018, 11:44 AM   #42
SMKN TA 95
Well since some of the pictures are not showing up anymore due to webshots removing linking to forums, here are some chassis pictures again.
RaceWire Solutions
Old 02-09-2018, 11:47 AM   #43
SMKN TA 95
Here are some pictures of the completed chassis going to the body show to get mated with the body.....then back at home in its resting spot for a while....
RaceWire Solutions
Old 02-09-2018, 11:49 AM   #44
SMKN TA 95
A few engine bay shots temporarily together....
RaceWire Solutions
Old 02-09-2018, 11:54 AM   #45
SMKN TA 95
From the time the truck came back from paint in March of last year, it sat all year during racing season with a car cover on it. I had been needing to get the truck back to the body shop to fix lots of paint issues......but I needed to make it steer.
After multiple orders of lots of different steering joints, couplers, adapters, etc.....we finally got a steering shaft mocked up with 3/4" wooden dowel that I turned into a DD shaft on my band saw. Once we got it mocked up, then we spent an entire day trying to accurately place the heim joint for the middle support. That was a feat in itself....but we got it, and it works great.
I also used a new Ididit steering column for C10's with a power rack. The section that sticks through the firewall is 5" shorter, which makes it somewhat easier to get connected to the rack.
Also, you see the rust on my brand new headers that were coated by Hooker Headers....junk. So those will be recoated as well.
Heres some pictures of the process....
RaceWire Solutions
Old 02-09-2018, 12:00 PM   #46
SMKN TA 95
While the truck was back at the bodyshop for a second time, we brought the chassis back to complete another big driveline issue has now been taken care of as well....custom, high hp 2 piece shaft from Inland Empire. Its their 502 kit, with 1350 U-Joints and upgraded larger diameter center carrier bearing and shaft.
RaceWire Solutions
