Old 11-23-2016, 08:26 PM   #26
Kw69
Kw69's Avatar
Re: is this truck a good buy at $2000.00?
Well like others have said, no on the 69. Who knows who has the title..... To much crap on that truck for sure. Your idea about a 69 dually and dropping in an Diesel engine sounds pretty cool. What Diesel engine are you planning to use? It would be a great project to keep tabs on.
2009 GMC 2500HD 6.0, 6 speed auto, stealth grey, 4x4 Z71, Bilsteins, Black Bear Tuned. Pulls the 10k fifth wheel all so easy.
1969 CST 350 black long bed, 3 on the floor, PS, AC, drum brakes, old school and love it.
Kw69 is offline   Reply With Quote
Old 11-23-2016, 08:59 PM   #27
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by gcm View Post
So you think the frame may have been cut on the green truck? Because it is a 157 in wheel base. But ya it is a 14000 GVW which I am sure you saw on the SPID.
Yes I do. Measure from the center of the front hub to the center of the rear hub (or ask the owner to do it) and see what it measures. I could be wrong but I'm betting it is shorter than 157"
LockDoc
Leon
Old 11-23-2016, 09:59 PM   #28
Aruba1
That is a truck that you don't post pictures of it online and/or tell your friends about it.
Aruba1 is offline   Reply With Quote
Old 11-23-2016, 10:42 PM   #29
I think it's just bobbed, but worth a check. I believe they were 84" cab to axle (center) dimension. The 133s are 60" C-A.
I think it's that no name HD 1t that is only known by that axle option. It has an HO72 rear, same as medium duties. It's a 10-lug and the front has 5. Same A-arm front end but beefier. The parking brake should be a drum in the driveline. If it has power brakes, or maybe they all do, it will have the booster under the floor with a breather up through the floor next to the driver seat. Those things are super cool.
