11-27-2016, 05:11 AM | #26 |
Re: Lookin for a 4 speed... need help deciding
I don't have the stock Bell housing. I have one out of a 72 nova.
11-27-2016, 10:50 AM | #27 | |
The Older Generation
If it had a three speed and the bell housing cross member is still there you would be better off using the original '67 bell housing and clutch linkage and just bolting the 4 speed on to that. Just my 2¢ worth LockDoc
11-27-2016, 11:21 AM | #28 |
That would've been nice. Would have saved me some money. And time.
11-27-2016, 12:39 PM | #29 |
Powder coated and rebuilt Muncie with an iron mid plate.
Brad handshoe |
11-27-2016, 12:54 PM | #30 |
Wow. Very nice. What do you have for crossmember?
11-27-2016, 01:03 PM | #31 |
I don't remember where I purchased it from. Summit Racing, maybe?
Brad handshoe |
11-27-2016, 01:50 PM | #32 |
OK. Thanks.
11-28-2016, 08:25 AM | #33 |
I would stay away from an M21 and M22 with a 3.08 gear set. First gear ratio is 2.20 in either one so you would be a dog off the line. M20's first gear ratio is 2.56 so that isn't as bad. I had a 69 SS Chevelle with a built 427 in it with an M-22. I had 4.56's in it and decided too try a 3.73 geared rear I had laying around for better cruising. Well, that flat out sucked off the line so I wound up putting in some 4.10's which was better... Find yourself a Super t-10 out of a mid to early 80's Z-28 camaro... I ran one for a while that had a 2.64 first gear ratio.. Tire size plays a big role...
11-28-2016, 09:20 AM | #34 |
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
With 3.08 rear gears I doubt it would pull the sheets off the bed.
11-28-2016, 09:49 AM | #35 |
I have 373 gears. I'm going to give it a shot. Wish me luck.
11-28-2016, 12:30 PM | #36 |
Custom Sport W/T
11-28-2016, 01:18 PM | #37 |
They had a close ratio 4-spd option on these trucks called the New Process 435CR (M-28) which is a massive and very durable transmission comparable to the 465.
First gear is still pretty deep at 4.56-1 but with your 3.07 gears you would be able to use 1st gear especially with tall tires. Gear spacing is pretty good. I've got a 3.73 rear dif and 31" tires and I still use 1st gear if I'm starting on an incline or I have a load. Yours would be even more useful (with the taller gears), maybe up to 30-35MPH? But even starting in 2nd it seems like a very good "3 spd". that doesn't have that big jump to 3d that the 465 has. Probably not what you are looking for, but good to know anyway I guess.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
11-28-2016, 02:22 PM | #38 |
Sorry didn't mean to hijack the thread. Lesson learned.
