Old 04-24-2017, 11:17 PM   #26
dayj1
Re: Tach to Pcm
Originally Posted by aknovaman View Post
Hate to rain on someones parade but your theory on the PCM tach output is incorrect. First the older PCM red/blue actually puts out a positive pulse from ground to about 8 volts. This transition is sufficient to trigger most aftermarket tachometers. The newer ecu don't work the same way. They actually ground the tach output wire for each tach event. The purpose of the pull up resistor is to do that, pull up the voltage to 12 volts between each tach event. Then with each tach event, the pcm output is grounded, thus transitioning the voltage across the external tach threshold. This can be verified using a simple oscilloscope to see the waveform. If you don't have the pull-up resistor connects to 12 volts, the newer PCM output will float anywhere from 1-8 volts erratically. There needs to be a solid/consistent voltage transition across the external tach in order for it to function reliably.
Respectfully, Aknovaman
Based on what you wrote, I believe you and I are in agreement on the operation of the newer ECMs. At least I think we're saying the same thing. I haven't noted the same behavior as you on the older PCMs, but I certainly haven't used/tested every hardware revision. From your description it sounds like some may have an internal pull-up resistor.
dayj1 is offline   Reply With Quote
Old 04-25-2017, 11:27 PM   #27
Liltroy
Liltroy's Avatar
Re: Tach to Pcm
I was wondering when you were gonna come back on here! Welcome back!!
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac
Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303
My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw
Liltroy is offline   Reply With Quote
Old 04-26-2017, 01:09 PM   #28
aknovaman
Re: Tach to Pcm
I have not visited this site mainly due to one member who appears to be a know it all jerk with a few years’ experience with LSx platforms but not mature enough to stay out of other people’s business. He has repeatedly insulted me and my 45+ years of experience in electronics and auto mechanics.
That being said, if someone wants to contact me about wiring, tuning or parts compatibility issues with their projects, via PM I will assist. I have neither the time nor patience to concern myself with other peoples self-righteous attitudes.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 04-26-2017, 01:13 PM   #29
Willie Makeit
Willie Makeit's Avatar
Re: Tach to Pcm
i understand how you feel. seems this site has an over-abundance of such types. it's tiring.
Willie Makeit is offline   Reply With Quote
Old 04-26-2017, 01:17 PM   #30
aknovaman
Re: Tach to Pcm
I have thick skin but value my time greatly.
FMCDH GBU and GBA
Old 04-26-2017, 01:21 PM   #31
Willie Makeit
Re: Tach to Pcm
hear. hear.
Old 04-26-2017, 01:39 PM   #32
Liltroy
Liltroy's Avatar
Re: Tach to Pcm
Roger that! I haven't been on here much lately either. And Just for the record, I appreciate EVERYTHING you've taught me and done for me!
Old 11-12-2018, 12:51 PM   #33
solidaxel
solidaxel's Avatar
Re: Tach to Pcm
Thank you both for your time and explanations and for answering the problems with my Tach
I am keeping this thread for future reference
Now on to the speedometer!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
