Old 01-03-2017, 07:00 AM   #26
Boog
laying low
Boog's Avatar
Re: Gas tank help
Originally Posted by KT57 View Post
Ok I see it my picture at the top. Where does it start under the hood?
Yes it starts at the fuel pump and runs along the frame parallel to the 3/8" gas line all the way back to the top of the tank. 3/8" supply line, 1/4" return line. Here's a pic of my tank from LMC with the later V8 sending unit and both lines attached.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-03-2017, 08:14 AM   #27
yuccales
yuccales's Avatar
Re: Gas tank help
Originally Posted by FirstOwner69 View Post
I have a '69 3/4 ton with a 350. It was made at Fremont, CA, in Dec, 1968, and sold new to me in Yorba Linda (southern California). It never had EEC with no holes in the tank other than the hole for the fuel pump and no tubes other that the fill tube for gas. The pump has one inlet and one outlet and looks like the one pictured. The gas line is 3/8". I would say you have the wrong tank.
My '69 C-20 was made 12-5-68. Funny how our trucks did not stray to far from Fremont! Yep, our trucks did not have any "smog stuff", as 3/4 ton and 1/2 ton had different emission requirements for the same year.
yuccales is offline   Reply With Quote
Old 01-03-2017, 10:55 AM   #28
KT57
Re: Gas tank help
Do you have the vent lines at the top of each corner?
KT57 is offline   Reply With Quote
Old 01-03-2017, 11:01 AM   #29
KT57
Re: Gas tank help
Yuccales, I went to high school in the Sacramento area. And I found my truck down south where I am at now near Ventura and I am the 3rd owner but it has never lived more than 50 miles from me. And I live in the same town as the original owner. Mine still has original dealer license plate frame from Oxnard.
Old 01-03-2017, 11:26 AM   #30
Boog
laying low
Boog's Avatar
Re: Gas tank help
I do not. This tank came from LMC too.
Boog
primer is finer
Old 01-03-2017, 09:36 PM   #31
yuccales
yuccales's Avatar
Re: Gas tank help
That's cool KT. Have you checked behind the seat for a build sheet? Have heard some Fremont trucks sometimes got two of them, one behind the tank? The original lic plate frame is always cool to have.
Old 01-03-2017, 10:30 PM   #32
KT57
Re: Gas tank help
Build sheet with pink carbon copy behind
Owners manual and warranty card
Tattered factory manual
Old 01-03-2017, 10:33 PM   #33
KT57
Re: Gas tank help
In original plastic bag
Old 01-03-2017, 10:44 PM   #34
KT57
Re: Gas tank help
Old 01-03-2017, 10:56 PM   #35
Green72long
Green72long's Avatar
Re: Gas tank help
New to group. I was looking around for info on cab leaks and saw this post about gas tanks. I have a 1972 c10 long bed and also have heavy gas fumes while driving. I was told that it could be the seal for the sending unit, so got a new seal and sending unit from LMC. I'm going to replace the rubber fuel lines in the cab when I drop in the new sending unit, it also looked like they were leaking. My gas tank is the EEC version with the charcoal canister and vent line behind the passenger, I can take photos if needed.
My question is, do I need to remove and drian the gas tank before I replace the sending unit?
Green72long is offline   Reply With Quote
Old 01-03-2017, 11:27 PM   #36
KT57
Re: Gas tank help
delete double post
Old 01-03-2017, 11:35 PM   #37
Boog
laying low
Boog's Avatar
Re: Gas tank help
Welcome to the boards. No need to drain the tank. That is unless the tank was just filled up. The sending unit drops in through the top of the tank so run the fuel level down below full.
Boog
primer is finer
Old 01-04-2017, 07:24 AM   #38
yuccales
yuccales's Avatar
Re: Gas tank help
Very cool stuff you got with the truck!
