#26 |
![]() Join Date: Dec 2013
Re: deadly alignment?
alignment shops of today just aren't equipped to work on 50 year old trucks ...GO OLD SCHOOL
http://www.hotrod.com/articles/ctrp-...ring-your-car/ |
#27 |
That's awesome!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#28 | |
solid axle and leafs are even easier.. |
#29 |
I made a similar mistake in assembling my truck. There are a few things that can be bolted on backwards, I.e. Upper control arms, lower control arms, idler arm, so one word of advice for people unfamiliar with these trucks (and I'm not saying this is what you have encountered) but the best suggestion I can make for people attempting to start a project like this is to take as many pictures as you can, prior to starting, for reference. My truck was a complete "Basket Case" I myself, had both upper control arms swapped left for right. When I took it in for alignment, the tech said something was dead wrong, posted a few pics here and within minutes, had it corrected, then back to the alignment shop, everything was right on the money then. I had installed my idler arm correctly, but some have installed it upside down. Just saying.....
Have a good one! Ben ![]()
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" ![]() “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” Last edited by snipescastle2; 02-16-2017 at 09:47 AM. Reason: Changes |
#30 | |
#31 |
Any worn, loose or damaged steering components would have been detected by a competent alignment tech. Control arms in incorrect positions will also be detected. (caster would be way out) A center link installed 180° out may be missed. The final step in an alignment is to center the steering wheel. To insure the steering wheel is centered the tech must test drive the vehicle (& also confirm there is no pull, the vehicle tracks straight & does not wander.)
Did the tech test drive your truck after the alignment? Did you get a readout of specs? What brand & model of alignment machine was used? What brand & model of alignment rack was used? Grumpy Old Man is right but the new alignment machines have videos to show you what bolts to loosen, which way to turn something to make the adjustment & display the numbers in red (bad) yellow & green (good) I',m pretty sure my grandmother could do an alignment if she had the strength to loosen/tighten the bolts (well, she'd have to be alive also) 1. Confirm the center link is correctly installed 2. remove the P/S belt to eliminate the power steering system 3. take it to a competent alignment shop |
#32 | |
![]() Join Date: Feb 2009
I agree fully. While the links may be straight forward, the details may be lost on young techs, because they lack classics experience. Add the abundance of Chinese parts they assume replace than repair. Add no sight of the correct parts and they've never seen them before anyhow. By some example are my Rochester carbs. Decades ago the guy threw on a manual choke no problem. Recently on another truck, I asked for the same, because I didn't want to deal with it and needed a choke soon. Despite the owner being your age-ish, I imagine, he looked at me like I was nuts and would only replace the carb. with an aftermarket. Shame the OP isn't nearby. I recently found a GREAT shop and alignment is part of the business name. The owner is an older gent as well, only none of the BS like the other shop. Good character and he's built many classics. Won a bunch of awards too. Bet he'd diagnose the problem in a minute. Other than that, safe to assume the steering column is good?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#33 |
![]() Join Date: Nov 2001
This might be far but throwing this out there, how's the rear suspension, u bolts tight . I drove a 67 home and when I got on the highway up to just a bit over fifty five it moved and jerk bad, scary ride home .
Nick Posted via Mobile Device |
#34 |
DO YOU HAVE A FRONT SWAYBAR INSTALLED?rhat makes a big difference
#35 |
![]() Join Date: Dec 2012
Ha! problem solved!!! maybe! I have installed the drag link backwards! I have not yet flipped it and taken it for a run (to busy! work, kids, lovely wife! not necessarily in that order!) but it will happen and I'll post an update! Ive got pics of the left, right, and upper control arms, I thought for a while I had those on backwards. and a pic of the truck just cuz its cool! you can't buy that patina! thats just crappy bodywork then left outside in a field for 30 years!
1969 Chevy C/10 Stepside, Short Box. LQ4/4L80E swap in progress! (Donations being accepted!) |
#36 |
laying low
![]() Join Date: Mar 2001
Congrats. You shouldn't blame the alignment shop for not catching this as said most of the younger techs aren't familiar with 40 + yr old trucks.
However you might give thought to using a different shop. The toe and caster being off certainly can cause drivability issues too.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#37 |
Are your lower snubber/bumpers towards the rear or the front? I can't tell from the photo and you don't have a swaybar on... just trying to confirm they're on the right way.
#38 |
![]() Join Date: Mar 2005
Glad you figured it out. By the way, great picture. I never fully understood putting the drag link on backwards until you posted that picture. I compared your picture to mine and now understand.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
#39 |
It looks to me from the photos like the upper arms are on the wrong side.
#40 |
Looks like the Center link is on backwards, the ends should kick out toward the front of the truck.
Brad handshoe |
#41 |
laying low
They are on correct since the lower shock mounts aren't visible in the pic.
#42 |
Snubbers go towards the rear of the truck. In the photo of the upper control arm mount where the brake lines are visible, they are also on the rear of the control arm. So I think they're fine, from what I can see.
#43 | |
I'm just surprised that such a simple thing causes such a big problem. I'm also used to working on my daily drivers, where they've designed things so it cannot go on backwards! but then again this truck rolled off the production line 23 years before I was born! and I didn't own my first vehicle until 16 years after that! Thank God that it was a nearly barren highway on the way home and no one got hurt!
#44 | |
Sure not all techs are going to know , but sorry.. most do. And those that don't it's only an all-data search away.. never mind the hunter machine showing how to do it. |
#45 |
Updates?
#46 |
I couldn't imagine driveing out on the highway with the steering feeling that wacky.
Back when i made the same mistake, That trucks steering felt so weird i could only make it too the end of the alley and back. I bet he is still out driveing his truck grinning ear to ear since flipping that link.... A sway bar would be a great addition
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. Last edited by midniteblues; 02-20-2017 at 10:22 PM. |
#47 | |
Thank you all for you input! I am very thankful for forums like this, I would have spent hundreds of dollars trying to diagnose this if it weren't for the trained eyes of the people on this forum! Thanks again!
#48 |
Good to hear!
#49 |
laying low
You are welcome. I'm glad it took care of your issues. Now get out there and enjoy driving it.
