#26 | |
Re: How many have restored trucks and left their front drum brakes?
I said that todays cars with their brakes will stop in 40-60 feet less and if it's a performance vehicle it'll be even more.. Todays 129.00 leased special will stop on a dime and you in a drum braked truck will just run into them.. as you can not on todays roads leave enough room /cushion without a vehicle filling it.. Seems those in area with lite or no traffic, have a skews experience.. and bad info.. I will not drive my drum brake chevelle in traffic because of this.. can't leave the cushion between me and the car in front of me.. and can't stop fast enough.. I like my clean driving record and no surcharges.. your mileage may vary. Last edited by James the III; 02-16-2017 at 10:09 AM. |
#27 |
2WD Jimmy
![]() Join Date: Mar 2005
I restored a 69 that had manual drums. When I added a power booster, that made all the difference. You dont 'Need' disks.
#28 | |
If you rear end someone it's not your drum brakes, you are following too close. Class A CDL, 800,000 commercial accident free miles (on drums) |
#29 | |
Again as seen as you missed it.. you can open up a cushion to have enough space.. but please tell me how to keep other drivers from pulling into that slot.. please I've looked for a way to control other drivers to no avail.. So what is the secret .. thanks.. comparing a semi with drums and a light vehicle is well, um, apples and oranges.. load weight to counter act the self energizing drum set up.. THAT is why they work ok in a semi.. when loaded.. and do nothing but lock when hooked to nada.. |
#30 |
![]() Join Date: Sep 2015
I left my drums on my 70 longbed. I do tow a 23ft airstream without problems, the trailer has its own brakes.
I did add a power brake booster, made a good bit of difference. Good rubber brake lines or braided lines would be better. The Best quality brake shoes you can buy, I read alot of articles online about drums and brake shoes and all had alot to say about shoe quality relating to brake fade issues. Im very happy with the way my truck stops, its a daily driver driven at a normal pace. |
#31 |
I'm driving on manual drums,which work just fine, probably as good as anything else from the late 60s. Lots of mountains here in BC, and if I were to take this 69 on a drive through the mountains, I would proceed a little more slowly and carefully than were I to take my disk equipped 98 Silverado.
The drums will lock all four wheels, but they would not stop the truck as quickly as a disk brake setup, because the heat buildup on a long hard stop will cause brake fade with the drums, less so with the disks. It all comes down to the intended use of the truck, and how important originality is. I would only change to disks if I was doing a 6-lug to 5-lug conversion, otherwise, drums'll do.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
#32 |
Old member
I've been on 3 Power Tours and haven't seen a vehicle rear end another one yet that where not the owner fault!
I have seen people get hit because they weren't paying attention to the road. They where looking at vehicles and didn't see the vehicle in front of them stoping. It has nothing to do with the vehicle. It has to do with thinking and watching what is happening in front of you. When your behind the wheel... your only job is to make sure you are looking out for your safety and anyone in the vehicle with you. No excuses. Don't blame the vehicle are the guy in front of you. Pay attention. 42 years of driving and never had a wreck. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#33 |
Differences in drum vs disk was really driven home in me when I owned two '69 GTOs. One with standard equipment drums, the other with optional front disks. Save for long hills, stopping at lower speeds was essentially the same. Drum fade at 120-mph is a whole other matter. My '69 C-10 long stepper will never see anywhere near those speeds, so 4-wheel manual drums have been fine. It actually had the factory originals on the back. And boy were they worn out!
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
#34 |
![]() Join Date: Oct 2011
Some good points about factoring in modern traffic and driving conditions.
I agree that these brakes are more than capable of stopping these trucks correctly. However, when you factor in that 99% of everyone around you now takes a lot of liberties on the road with their modern vehicles abilities that puts your ability and your trucks ability to handle it at much greater risk. I think when everyone had these vehicles on the road (1970's? and older)...people generally knew they couldn't 'dart' in and out of traffic...the cars simply couldn't do it but today they can...and they do. Good points. Coley ![]()
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
#35 |
![]() Join Date: Nov 2004
That's the issue I have where I live. Doesn't matter if it's a 70mph interstate or a 4 lane 45 mph road, if there is a gap someone will cut you off to fill it. Traffic is absolutely terrible here. I've had people pull in front of me in my lane when the whole line of cars was already slowing, so then I had to really get on the brakes, or the worst is when a car 2 cars up is turning, the jackass behind them doesn't want to wait behind them while they turn, so they dart over to the next lane when they're almost behind that car, and all of a sudden I'm going full speed behind a car that is stopped or almost stopped and I had no idea. The road I work off of is a 4 lane road with no left turn lane and this happens literally daily, either to me, or I see it happen up ahead.
What absolutely ended the disc/drum debate for me was test driving a 65 Mustang I was looking at to buy. The drum brakes felt good at low speeds, but right after I got going a car pulled out in front of me so I got on the brakes and it pulled so hard to the right because they weren't adjusted properly I almost put it in the ditch. You don't have to worry about adjustment or steering pull on discs. I put 3 point seat belts and front discs on all my old stuff.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#36 |
My son, who drives a 2015 Silverado daily, drove my 70 C2500 w/ 72 front discs for the first time a couple of days ago. He was very surprised how much force the brakes required (part of this was being on high idle).
Even with a fully restored disc system they're not quite new vehicles! Other than "just because" I wouldn't upgrade a drum front unless I was towing or driving in the mountains where fade was important. Or driving through a lot of water I guess. Otherwise I'd be totally happy with drums.
#37 | ||
Early Classic did a comparison on stopping distance with stock vs. their disc setup and suspension components on a 60-66 C10. To be fair, I'm sure the original stuff was completely worn out, and it is an article to help sell their suspension components, but they came up with a 30' difference in stopping distance with some springs and tires:
They then did the disc brake upgrade and it dropped the stopping distance to 172': Quote:
For comparison, let's say a C10 with discs can stop in 175 ft. A 2016 Silverado can stop in 137', and F-150 in 140, a Ram in 147' and a Tundra in 153' and these are 5,500 lb beasts. http://news.pickuptrucks.com/2016/02...g-braking.html The average family car can stop in 130-140' and a modern sports car in under 120'. #'s from 2011: http://www.consumerreports.org/cro/m...ance/index.htm Just wanted to show the vast difference in braking between modern cars and our old trucks. At highway speeds you need to damn near be 100' back behind a modern car with drums. Where I live... good luck leaving more than 20-30' ![]()
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 02-16-2017 at 01:33 PM. |
#38 |
![]() Join Date: Mar 2003
1968 GMC 3/4 ton big block, drum brake front and rear, never had any stopping issues loaded or unloaded. It's knowing your vehicle and what it can do and not do. I've had this truck overloaded several times with firewood and scrap steel.
#39 |
![]() Join Date: Jun 2005
My 70 has drums all the way around. Not a race truck, though it does have a mild 402 and in normal driving it stops just fine.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#40 | |
Montana? Some pretty tough driving here at times, but my commercial driving was mostly in the south. apples to oranges? Class 8 drum brakes are not "self-energizing" they are a single acting system. they work OK when loaded to 80,00 (or over), work best at moderate loads &, with experience, work well when running empty. Drum brake systems on our trucks are "self-energizing " (duo-servo) & the braking systems on all vehicles are engineered to work with the weight & load parameters of that vehicle ( some better than others) Bottom line: If you have an accident with a drum brake vehicle THAT IS IN PROPER WORKING CONDITION it is not the brake system's fault it is the driver's. |
#41 |
This thread is hilarious!
You don't need disc brakes!!! LOL Reading some of these post's remind me of conversations with my former spouse......... ![]() My 67 and 68 C-10's will both have front disc brakes before they ever roll on a road again. Neither of my pickups will be driven like grand dad did back in the 60's. Driving an old pickup that had front drums that were truly NOT adequate "in the day", these days around vehicles that can ALL stop way better, is a silly thing to me, my opinion.......................... 3/4 and one ton's have considerably bigger drums and shoes, I have never driven one of those, they do not figure into this thread's OP, my opinion. Vehicle safety is the most important thing to me. There's an old saying, Nobody ever got hurt in a vehicle accident because it wouldn't start, but many have perished because it's brakes didn't perform well.... Carry ON!!! |
#42 |
The Niner
![]() Join Date: Nov 2010
I still run front drums on my C/20 and don't plan on changing them out.
From April to October I drive about 6000 miles a year in every conceivable traffic situation and I'm more than happy with the way the brakes perform.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
#43 |
since you say all your brakes are new drive it till they need replacement then decide. I have owned several vehicles with drums and they stop just fine.people drove just as crazy in the 60,s and 70,s if not worse. you have to drive knowing your trucks capabilities. I have been driving 48 years in and on trucks cars motorcycles and cannot remember seeing an accident that could of been avoided by a disc conversion.
#44 |
Buying disc brakes is way cheaper than replacing sheetmetal.
Look, I love old stuff. I fly a 1946 Piper Cub all the time, work with Farmalls, and daily drive a 1970 C10 during the summer. But I also use a remote control, cell phone, and ride elevators instead of stairs. Sometimes technology moves on even though the old stuff still "works fine." There's NO WAY I'd drive 250+ miles everyday on crowded Power Tour routes without discs. I've done 6 or 7 Power Tours. The traffic can be insane and a lot of people drive in groups, which leads to weird behaviors of people trying to keep up and stop together. As said before, if all I did was cruise backroads drums are a perfect solution. Definitely not in big city rush hour traffic. Remember, everyone thinks they're a good driver.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
#45 | |
Don't forget, shocks, springs, and sway bars can have a great affect on braking distances as well! I actually haven't taken the C10 on the tour because it gets light in the ass in the rain and it seems to like to rain on the tour.
#46 |
I rebuilt my drums all around on my 68 with a booster and it is just fine. Just survived a 30 mile daily commute through a hard winter in Boise on freeway and city driving. I just can't justify the spend on disk unless I were to find a donor that was complete and even then its not my primary vehicle anymore, now its my truck for when I need a truck so I don't think I will go to disk.
#47 |
if a ''power tour'' and rush hour traffic is so scary you need to upgrade tires ; seat belts; add air bags; wear a helmet the list goes on. I would just buy a new truck and stay out of that death trap.
#48 |
![]() Join Date: Oct 2013
I'm not racing mine. People turn heads cause how it looks not how fast it is. I'm leaving my drums. Easy and cheap to maintain and suits my needs. Just my two cents
#49 |
Wow this created a good conversation. Thanks for the input guys. I think I will leave the drums for now being that they are new and if I don't like them I will do the swap.
#50 |
This is a great post and funny seeing how defensive some members get over others opinions lol. The bottom line up front is, disc are better. They are more effective, easier to work on and don't fade like drums. I'm sure most of us are not talking on rotary dial phones with cords anymore, but they worked? Why do I need a cell phone when this one worked just fine? Disc are definitely worth the upgrade. It all boils down to personal preference at the end of the day, but I would never switch from disc to drum and I'm not trading my iPhone for a rotary dial phone.
