02-20-2017, 02:01 PM | #26 | |
Re: 72 suburban sheetmetal
The B pillar like you already cut out, you can cut it for shipping between the upper hinge and the raised outside reveal between the 2 doors The upper piece I need is above the front drivers or passenger doors, it needs to be pretty rust free. Alternatively I could use the same piece above the 3rd door, it shorter I think and has hole plugs in it. I need the 2 3rd door lock swivel pieces, rods and clips, they transfer motion of the lock knob via rods from the front of the door to the latch at the rear. |
02-20-2017, 02:24 PM | #27 | |
I can handle shipping if you can put it on a pallet of some kind |
02-20-2017, 09:04 PM | #28 | |
Equal opportunity joke ofender
I have two pcs of the upper door channels as shown in the pictures one is about 19'' & one is about 22'' mainly just surface rust, no breakthru that I see. I also got the 3rd door taken apart and pics attached. The latch itself is decent but the center pin does have some play. Not sure if you were wanting that as well as the pivot parts. .
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
02-20-2017, 09:06 PM | #29 |
do you still have interest in these items as well? I will finish pricing everything in the morning and pm you with it
02-20-2017, 09:08 PM | #30 |
Rob
none of the regulators turned out to be any good. The 3rd door works fine but when I got it out of the door it is missing one of the nylon wheels.
02-20-2017, 09:53 PM | #31 | |
I don't need the door latch, just the lock pivot parts. I only need the shorter above door cut. How much shipped for that stuff and is paypal ok? How are the door panels, color? |
02-21-2017, 06:32 PM | #32 |
Still have the passenger side b pillar?
1972 c10,2wd,long bed,250,4spd----> 1972 SWB Fleetside 4x4 12v Cummins build thread http://67-72chevytrucks.com/vboard/s...d.php?t=513791 |
02-21-2017, 07:05 PM | #33 |
Everything in post 28 and the right B pillar sold to Randy500
02-21-2017, 07:22 PM | #34 | |
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
02-21-2017, 09:05 PM | #35 | |
I gotcha covered on the pillar. Did you find out anything on the other fenders yet? If you end up with them I will just mail this or if you still need the fenders i will bring it with them. thanks Richard
02-27-2017, 12:00 PM | #36 |
Is there any part of the pinch weld down below the rockers that is salvageable?
02-27-2017, 01:01 PM | #37 | |
Directly below the rockers was complete toast. The only section of pinch weld area on the entire truck is a 30" section I have squared off in the picture and that is only on the outer pc. The inner pc is rusted up as shown. Outer pc has some surface rust but cant see any pitting or breakthru until the obvious hole near the wheel arch. .
03-03-2017, 02:38 AM | #38 |
Thanks for the reply. Im going to pass for now.
03-04-2017, 07:32 PM | #39 |
Richard, got the parts yesterday, thank you for your time and parts....good seller
03-05-2017, 01:43 PM | #40 |
Thanks Jim
03-05-2017, 02:28 PM | #41 |
I got my parts too and installed part of that pillar, thank you!
Excellent packaging and quick shipment. |
03-05-2017, 02:30 PM | #42 | |
Richard
03-05-2017, 03:58 PM | #43 |
I need the interior metal panel where the fourth door would go.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
03-05-2017, 03:59 PM | #44 |
Do you have a rear wiring harness?
03-05-2017, 04:13 PM | #45 | |
are you talking about the removable panel or the actual metal wall of the interior? I don't have any metal door panels, all of mine are plastic 72 models. If you are talking about the actual metal wall, the last picture in post #4 will show what I have but it is rotten below the floor line as shown in 2nd picture of post 37 thanks Richard
03-05-2017, 04:25 PM | #46 | |
03-05-2017, 04:26 PM | #47 |
I do have the complete wiring harness from this one from the a pillar all the way to the back. I was able to get everything out without cutting but without unpinning the plugs it would never go back in in one pc. even unpinned I am not too sure it would feed real easy. The hole in the rear pillar that it feeds down thru was very small. I have not listed it yet as i was trying to research value on it but have been coming up skunked. here are some pics
03-05-2017, 04:30 PM | #48 |
you mean this area squared in red?
03-05-2017, 04:40 PM | #49 |
Yes, but that pic woke me up. I will probably just cut up a rusty door for the patch.
I'm still intererested in the harness. Thanks
03-05-2017, 04:45 PM | #50 | |
As far as wiring harness, do you need the tail light sections as well or just the main feeder that runs front to back? Richard
