#26 |
![]() Join Date: Oct 2013
Re: brake booster question
Hey Tom, any update to your situation with the brakes?
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
#27 | |
#28 |
In the factory service manual, there is an actual tool number that they suggest. I can't tell you off the top of my head what it is, but the "design" of it is basically a piece of steel of gauge thickness,about an 1" or so wide and about 4" long that has the last inch or so bent into an "L" shape with a "U" groove in the end of the long side of the tool, this end is slid under the front mounting bolt of the combination valve. When installed the leg of the "L" is aligned with the "warning piston" and acts as a "stop". I made my own out of a piece of sturdy sheet metal that I cut with my "tin-snips" and used my bench vice as a brake press. I then used a small "C-Clamp" to clamp it to the combination valve, making my version a little shorter than the one that mounts under the front mounting bolt. Worked fine for me.
#29 |
>>"The pin" that is "depressed" in actuality is a preventative precaution. And is not so much "depressing" it, but rather preventing the "warning piston" from becoming un-centered during the brake system bleeding process.<<
Not at all how it works. The Metering Valve opens when the pressure exceeds about 50 psi. When there is air in the lines and you are trying to bleed the air out, THERE IS NOT ENOUGH PRESSURE to open the Metering Valve and it is very difficult to bleed the air out of the lines. If the pressure will not open the valve, THEN YOU MUST MANUALLY OPEN the valve. There are TWO TYPES. Some Valve Pins must be pulled OUT to open them and some Valve Pins must be pushed IN to open them. The two types of tools for the two types are shown below. There is no physical connection of any kind between the switch piston and the Metering Valve.
'67 GMC 2500, 292, 4spd, AC |
#30 |
RichardJ everything you are stating is True. Except for your reference to one of my earlier posts. Nowhere did I mention "Metering Valve" or that there was "any kind of connection" between the "Warning Piston" And "Metering Valve" physically nor figuratively. However, there is a relationship between the "Warning Piston" and the "Proportioning Valve". There is NOT a "physical connection of any kind" between the "Warning Piston" and the "Proportioning Valve" UNDER NORMAL OPERATION of the "Combination Valve", i.e. driving and braking. We all know liquids cannot be compressed( in the normal realm of things), air however can and does compress under pressure. If air were introduced into the "Secondary Piston Bore" and the brakes were applied, the force exerted by the "Secondary Piston" on the Hydraulic Brake Fluid would begin to compress the air, normally this void would be occupied by Brake Fluid and the "Proportioning Valve" would begin to open at the correct pressure, the presence of air in this chamber, however, allows the "Proportioning Valve" to operate in a way that is not intended. Resulting in a "Physical Connection Between the Warning Piston and the Proportioning Valve". With the electrical circuit complete for the "Brake System Disproportioning Warning Light", we get that bright red "BRAKE" indicator light that we all love seeing on our gauge cluster after we "successfully and completely evacuated all air from the Brake system...."
#31 |
![]() Join Date: Jun 2012
no update yet mike. Actually haven't driven the truck much since then. And also didmt know you had asked either. I havemt been on the site alot lately. Been super busy.
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
