Old 03-15-2017, 06:33 PM   #26
YBNORML
YBNORML's Avatar
Re: Driver Quality Pickup truck Lock Set
Originally Posted by LockDoc View Post
Yes it would. We could do some swapping. They don't usually go bad except the tumblers get worn out, but I can replace those with new ones.....
LockDoc
Excellent, give me a few days to search the shop.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 03-16-2017, 05:44 AM   #27
1972larry
I would take locks and keys if you have a pair
1972larry is offline   Reply With Quote
Old 03-16-2017, 07:51 PM   #28
LockDoc
The Older Generation
LockDoc's Avatar
I will put you on the list.
LockDoc
Leon
Old 03-16-2017, 07:54 PM   #29
LockDoc
LockDoc's Avatar
Originally Posted by undertaker72 View Post
glove box loc assy
Yes, I have a GB lock if I can come up with the others....
LockDoc
Leon
Old 03-16-2017, 08:02 PM   #30
undertaker72
undertaker72's Avatar
LockDoc
if you need me to send some others I can do that , hell I should have you do a bunch of my orphans in match sets and that way ill have them , ive bought 4 or 5 sets from you , , seams every truck that's been parked for a while they have been robbed or lost keep me in mind , and if you want I can do thet thanks kevin
I aint nobody DORK
1972 Cheyenne super k10 swb 350 4speed posi hooks
1934 ford 3 window blown 355
1969 Camaro hugger orange hounds tooth
undertaker72 is offline   Reply With Quote
Old 03-16-2017, 08:13 PM   #31
Choclabnut
Leon,
Silly question time...
My key is basically worn down to nothing, it still seems to work.
Do you have the ability to re-key a set of locks and ignition to a better key?
Basically take a different key that's not worn flat and change the tumblers to match it?
I need your services if that's a possibility!
Choclabnut is offline   Reply With Quote
Old 03-18-2017, 03:13 PM   #32
LockDoc
LockDoc's Avatar
Originally Posted by Choclabnut View Post
Leon,
Yes, I can do that. I can either re-key your cylinders or cut a key to factory specs for your locks.... If the key is that worn the tumblers are probably worn pretty bad too and should be replaced....
LockDoc
Leon
Old 03-18-2017, 03:58 PM   #33
Dustmaker65
Dustmaker65's Avatar
Hi Leon. The lock sets came today.
Thanks!
Jimmy
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 03-18-2017, 10:50 PM   #34
LockDoc
LockDoc's Avatar
Thanks!
Jimmy
Thanks for letting me know Jimmy.
LockDoc
Leon
Old 04-03-2017, 10:07 PM   #35
Cplfitz
I submitted a request for locks on a different thread. Question I have is if the locks I currently have can all be rekeyed to the same? If so, how is the best way to do this? Cost?
Cplfitz
Cplfitz is offline   Reply With Quote
Old 04-04-2017, 01:26 AM   #36
LockDoc
LockDoc's Avatar
Cplfitz
Yes, I can key the locks the same as long as the key you have will physically fit into all of the locks. There were four different keyways for the '67-'72 Chevy and GMC trucks and they will not interchange.
You would have to send me the locks you want changed and the key you want them changed to. If you do not have any keys you would have to send me all of the locks. Cost depends on how many locks I would have to change to make a set. Usually runs about $7 per lock + return postage unless they are really nasty inside.
Thanks,
LockDoc
Leon Rowell
Leon
Old 06-03-2017, 06:55 PM   #37
FL71C10
Hi, Leon
Do you have any more matched sets of door and ignition locks? I got a new truck and the door locks don't work.
Driver quality is ok, as the truck is a 20 footer.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 06-03-2017, 11:27 PM   #38
LockDoc
LockDoc's Avatar
Originally Posted by FL71C10 View Post
Hi, Leon
Not at this time. I have plenty of door locks but no ignition locks. If you want to send me your ignition key I can key a set of door locks to it for about 13 bucks sent to you.
LockDoc
Leon
Old 06-06-2017, 09:28 PM   #39
flashed
Do you have another set of driver quality 72 door locks ? And if so how much shipped to Ga and can I mail payment ?
flashed is offline   Reply With Quote
Old 10-18-2017, 11:50 PM   #40
ItzhakRoberto
Looking for a set for a 72' ....with shipping to So California .... let me know please ! thank you!
ItzhakRoberto is offline   Reply With Quote
Old 10-19-2017, 09:38 PM   #41
LockDoc
LockDoc's Avatar
Sorry I don't have any used sets at this time.
LockDoc
Leon
Old 12-08-2017, 11:24 PM   #42
72 paul
Leon,set arrived today.Thank you. Paul.
72 paul is offline   Reply With Quote
Old 12-09-2017, 05:43 PM   #43
LockDoc
LockDoc's Avatar
This is actually a different thread but thanks for letting me know Paul....
LockDoc
Leon
