Old 02-19-2018, 06:58 PM   #1
87Skier
87Skier's Avatar
Re: 4.8L/6L90E swap???
Should be this one. You can add the other channels and see what shows up.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 02-19-2018, 07:31 PM   #2
First c10
First c10's Avatar
Holy crap, I must have missed the whole brake tab or file. I am assuming yes means applied?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 02-19-2018, 08:07 PM   #3
First c10
First c10's Avatar
Ok.
If I don’t have the blue/white strip wire connected to anything I get a yes on the status. I connected the blue/white strip wire to my relay with no resister and it reads no. I touch brake and I get a yes. This is without the truck running just key on. When I start the truck the status reads NO when unplugged and stays a NO no matter what.
Always a NO. When running.
I shut truck off and it goes back to working YES pedal depressed and NO pedal released.
Not sure what to try.
GO GO!!!
Old 02-20-2018, 12:29 AM   #4
87Skier
87Skier's Avatar
Yes means applied.
Old 02-28-2018, 08:27 PM   #5
First c10
First c10's Avatar
Hey 87skier. My truck is d5.
Do I adjust the tap up/tap down as mine doesn’t show force shifts.
GO GO!!!
Old 02-28-2018, 09:26 PM   #6
87Skier
87Skier's Avatar
If it shows "D5" in the scanner then make sure it says D5 in VCM Editor.
Those tables are just the maximum's, so it will shift regardless of input. It may prevent the TUTD system from enabling if the tables are set incorrectly. For now you can set all the upshift speeds to 100, and all the downshift speeds to 0 to rule this out.
Old 03-01-2018, 02:05 AM   #7
First c10
First c10's Avatar
First off I want the say thanks for the help.
I was able to use your numbers as a base line as for some reason my settings were at like 317. I checked yours against a 2012 Camero e38 ecm set up and they are almost exact.
I set them to your numbers and was able to get the tap up and tap down working. I do have to alter them as they want to auto shift earlier than I want. I am sure it’s rear gear and tire difference. But the TUTD works great.
I will be starting a thread about this TUTD set up. I would love for you to be part of it. Are you ok with me using your info?
Let me know or maybe you can just add to my thread.
Here is a teaser!!!
GO GO!!!
Old 03-01-2018, 01:07 PM   #8
87Skier
87Skier's Avatar
I am glad you got it working.
Please use all the info you want, and I can add to the other if you want.
I like the shifter setup. I don't think I've seen anyone put a new style shifter in and use the buttons that way.
