04-25-2017, 07:58 AM | #26 |
Old member
Re: LS swap radiator, other than entropy and R&D
I haven't had any issues with the radiator at all. All aluminum and no plastic very nice unit.
http://67-72chevytrucks.com/vboard/s...d.php?t=681842
04-25-2017, 10:41 AM | #27 |
agreed. everyone is in a rush to buy an aluminum radiator and i'm not sure i understand why. copper is much better at heat transfer / thermal conductivity (by almost twice) versus aluminum and OEM style radiators are normally less expensive and require zero modifications to the truck. <shrug>
04-25-2017, 10:52 AM | #28 |
meowMEOWmeowMEOW
Depending on the year of the truck being swapped, many of us never had a radiator to start, and some of our recipients never had a rad capable of supporting 2 fans or trans coolers etc.
04-25-2017, 11:15 AM | #29 |
what OEM-style radiator that has been produced in the past 60 years can't support 2 fans in a shroud or a tranny cooler?
04-25-2017, 11:30 AM | #30 | |
1968 LWB C20 / AC / Wood Bed |
04-25-2017, 11:45 AM | #31 | |
Old member
My truck ran a factory radiator for years. It ran at 190*-200* all the time. I went to the aluminum radiator and it takes a lot of heat to get it up over 180*. That's running AC full blast. Try and find a full metal replacement radiator with no plastic in it. I'll just about bet you can't find one NEW! I'll also say a new aluminum one will cost less than a all copper new one also if you do find it.
04-25-2017, 12:00 PM | #32 |
I bought the cheap aluminum radiator off of Ebay for the SBC and then bought some coolant hose adapters from a jaguar v8 swap site that fit the hose size I needed. cut off the old and welded on the new.
Cost me like $150 or so when it was done and has worked well enough. There was also a connection I used for steam that was already in the radiator. |
04-25-2017, 07:09 PM | #33 | |
meowMEOWmeowMEOW
Plenty of vehicles don't have fluid passages for a trans cooler. Some was an option, others were HD use only...and plenty had M/T. If you want to run without a dedicated trans cooler, you'll want a place for it in the rad. The AD and earlier rad's would be too small for most of the cheaper large diameter electric fans, so to run 2 fans, your going to the smaller units (they still work, but not everyone wants to spend the extra $ for that, just to retain an old rad style, if they have to buy a radiator anyway. ) I'll be vain and add that copper is kinda ugly under the hood if the style doesn't fit the look of the truck/engine. Aluminum is also strong, light, and easy to repair (more guys know a TIG welder than they do guys with brazing skills)
04-25-2017, 09:07 PM | #34 | ||||
now, if you want to talk weight savings (since thats what spawned the advent of aluminum radiators in the motorsports circles) then you have a valid argument. Quote:
anywhoo, i notice a trend in this thread: the only guys that are pro-cheap chinese aluminum radiators are the guys who have already bought them. |
04-26-2017, 07:43 AM | #35 |
Old member
Cheap yes, but over 3 years in use 2 power tour over 3500 miles each in 7 days and not one problem. The copper is fine if that's what you want. But todays world the aluminum will cool better per the way they are designed.
Yes I have already bought mine but I also had my truck 31 years and ran the lesser copper one for the most part of those years in fact I have 2 of them in my building that I took out because they are crap the last one had plastic tanks lasted about 3 years of everyday driving. Cheap crap is out there no matter where it's made. I'm just stating facts about mine. Ugly under the hood is opinions as said above. I like the aluminum one I have. It works great it was cheap enough and everyone likes a good product for a good price and that's what I have. There is no doubt there are cheap ones out there but do your home work before you buy.
04-27-2017, 12:45 PM | #36 | |
Andy, be careful running at temps lower than stock. You want your engine to get hot enough to boil off condensation and other water/stuff that's gotten into the oil.
04-27-2017, 05:26 PM | #37 | |
Old member
05-23-2017, 07:41 PM | #38 |
Any other options?
My mother is a recent cancer survivor and this truck build is for her |
05-23-2017, 08:02 PM | #39 |
Looking at this but not sure if it will fit in the 66
http://www.griffinrad.com/load_detai...t&model=Impala
05-23-2017, 08:47 PM | #40 |
Just ordered this for my 69.
https://www.summitracing.com/parts/gri-8-70013-ls We'll see how it goes. Also, for what its worth: While copper is more conductive that aluminum, no doubt about that, the soldered joints between the copper fins and tubes are much less conductive than the welded connection between the aluminum fins and tubes. |
05-25-2017, 12:41 AM | #41 |
Bump
05-25-2017, 12:59 AM | #42 | |
https://www.amazon.com/APDI-Radiator...s=APDI+8010284 It'll cool an "LS" engine just fine and it'll bolt right in. It'll also save you a few bucks to spend elsewhere as these swaps are expensive enough already. If you prefer the looks or performance of a particular custom radiator, by all means, buy it. But it's not "necessary". |
05-25-2017, 08:10 AM | #43 | |
https://www.amazon.com/Chevrolet-Alu...X8MYDRBNTQDKPN |
05-26-2017, 12:19 AM | #44 | |
05-26-2017, 12:13 PM | #45 | |
The factory four core in my truck will NOT sufficiently cool my big block with the AC on if it's a hot day. The aluminum two-tube with dual SPAL fans in my Camaro WILL sufficiently cool a big block all day long. Fans don't even come on until you're stopped at a light. That's all I know. Just experience, no theory.
05-26-2017, 12:15 PM | #46 |
I just installed a radiator in my '51 made by Superior Radiator. It fits great and I will be buying from them again for my '64 Suburban
http://www.wwwsuperiorradiator.com/1...7_chevy_trucks |
08-09-2019, 02:06 AM | #47 |
Bump....
I am still on the hunt. Went through 3 rads so far...lol. Still having clearance issues. Tomorrow will be number 4. I think that one will fit. hehe cross our fingers. |
08-09-2019, 03:14 PM | #48 |
I'd avoid the Griffin. Mine literally started separating after a little over two years. Looking at the Be Cool Bone Yard Series or Northern but for now I'm running the old Speedway or Summit aluminum radiator from my smallblock.
08-09-2019, 06:16 PM | #49 |
I’ve got 4 years and over 10,000 miles on my speedway radiator here in Texas where I drive it all the time. This is for my LS swapped truck and I have no issues. I am building a LS swapped K5 right now and will be putting in a similar radiator for it. You really can’t beat the speedway/summit/jegs branded radiators for the price and quality.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
09-23-2019, 11:18 PM | #50 |
Just ordered this from AutoCity on eBay:
1967-1979 Chevrolet GMC C-10 Pickup LS Motor Swap Radiator Shroud & 2 12" Fans Item number 352233489480 I will provide feedback once it's in and running. Had good reviews from the sellers. |
