#26 |
Post Whore
![]() Join Date: Feb 2016
Re: No traction
Lots of good input here. Just thought I should tell you anti-squat modifications are for road handling not drag racing. You want the rear end forced down under acceleration for better traction. (This wont happen until you get a certain amount of traction, so take care of some other things first.) That is one reason those exotic sports cars do poorly at the drags, they have lots of anti-squat. You can do one or the other well, but not both. The cheapest and easiest thing is learn how to drive the truck out of the hole with the traction you have. This is something every drag racer learns, from John Force on down. John Force wins fans with burnouts not races. With the rear gears you have once the wheels are spinning they are not likely to stop, so take it easy at the start. I used to run 13.70's in my GTO with 2:75 rear gears (@ 106 MPH) on L-60 street tires. Its lots of fun to pass them on the top end.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#27 |
Re: No traction
I was told that anti squat would help since the truck is lowered 4 inches in the back with bringing the trailing arms back to stock level. So do I not want to install them at all when I get the trailing arms off?
#28 |
Re: No traction
#29 |
Re: No traction
My truck is a leaf spring truck with a flip and re-drilled stock upper mount in the rear where I used stock length front shocks so I'm not the guy to ask! But the Bilstein 5100 (zinc bodied shock not yellow painted) is where I would spend my money.
#30 | |
Re: No traction
it only made a traction issue worse.. 2 tires (posi) with a pinion angle that never loads the tires. will just spin, like the peg leg.. only now it's slides sideways.. looks cool, but doesn't get you moving In a truck with nothing over the rear tires.. the pinion angle and instant center means EVERYTHING.. Could not ask for longer ladders to leverage off of.. but you need the correct settings.. the lowering it.. did it no favors here.. the pinion angle and long arm mounting points need to change.. Posi will help.. but not where I'd go first. |
