Old 05-15-2017, 05:39 PM   #26
chevyrestoguy
chevyrestoguy's Avatar
Re: 60-66 Radiator Over flow tank
Because the factory windshield washer system is marginal at best, I wound up using the factory washer bottle as my radiator overflow. I ran a hardline from the nipple on the radiator neck, and tucked between the radiator and the shroud and then routed it over to the driver's side of the core support, right to the washer bottle. Slick and looks 100% factory. Just make sure you run the suction tube all the way to the bottom of the bottle, leaving about a 1/4" gap. The overflow doesn't need to be pressurized, just vented. The factory washer bottle cap has a tiny hole in it to vent the bottle.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 05-15-2017, 06:49 PM   #27
par4tom
If your in a hot, humid client and don't want to dump your overflow fluid, then put one on. No harm in having it.
The polished one you show has two hoses going into it and looks like what I used. I used some supplied "L" brackets to mount it as you can see below. This is a pretty simple install and rather instant gratification.
Funny...first time I hooked mine up I got the two hoses going into the reservoir backwards. Started dumping water first time it got hot and it took me a couple of days to figure it out. Should have looked inside the reservoir BEFORE I hooked it up...
Tom
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 05-21-2017, 10:43 PM   #28
65chevysub
65chevysub's Avatar
Originally Posted by reed62 View Post
I went with an early 1990's Toyota overflow tank. Nice and narrow and mounted it on the driver's side radiator support.
Reed62. Do you have any pictures of your overflow tank?
65chevysub is offline   Reply With Quote
Old 05-21-2017, 10:58 PM   #29
reed62
reed62's Avatar
Yep....Here it is. It sits pretty even with the top of the radiator support and I used another Toyota bracket from a Sequoia overflow tank and bent it around to fit this tank.
reed62 is offline   Reply With Quote
Old 05-21-2017, 11:04 PM   #30
65chevysub
65chevysub's Avatar
Thanks. I like the small size and can mount it where my old square "brick" was.
Old 05-21-2017, 11:11 PM   #31
reed62
reed62's Avatar
Yep and when I found it I grabbed it. It should have enough capacity to hold what little liquid will make its way to the tank. For $9 it was a done deal in my book. It was off a pickup by the way. Not sure if the cars have the same style or not. The little extra tube that points down is used for the venting feature.
Old 05-21-2017, 11:24 PM   #32
65chevysub
65chevysub's Avatar
Thanks. Next time Im in Prescott, I will go to U Pick It and look for one. I just have to get the rad neck turned around. The nipple points toward the battery and I have my old overflow in between the grill and the raf support do the hose would fit.
Old 05-21-2017, 11:39 PM   #33
reed62
reed62's Avatar
My nipple points to the battery too. The overflow tube just makes a gentle curve over the negative terminal and runs between the radiator top tank and rad support.
Old 08-01-2017, 11:01 AM   #34
The Rocknrod
Moderator
The Rocknrod's Avatar
Looks like they didnt call it a overflow tank, in the assembly manual they call it a Condenser Asm.
Old 08-01-2017, 11:04 AM   #35
The Rocknrod
Moderator
Shows C-K 10-20 too.
Old 08-01-2017, 11:53 AM   #36
jbgroby
jbgroby's Avatar
THANKS, I knew I was not crazy.....Please tell the wife....
jbgroby is offline   Reply With Quote
Old 08-01-2017, 06:41 PM   #37
Classic v6 GMC's
Classic v6 GMC's's Avatar
Thanks for posting. Looks like the same setup on the gmc suburban I previously posted.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 08-02-2017, 07:12 PM   #38
Ken Cook
Ken Cook's Avatar
Originally Posted by 64shortbox View Post
I'm not sure if you are looking for a factory overflow tank (I've never seen one) or one that looks factory and fits our trucks. - If you are looking for an overflow tank looks good & fits our trucks you might look at the ones for the Ford Trucks. They are a Radiator Over Flow/Windshield washer combo and the cut of the tank fits the angle of our inner fenders almost perfectly and as a plus you can now add windshield squirters at a later date if you want. This is the set up I went with on my 64 C-10. I moved the horn relay and voltage regulator to the other side of radiator support using the original mounting holes and grommets for both. I later though did go to a one wire 120 amp alternator. I got mine from the wrecking yard BUT you can get it brand new from Rock Auto for $28.00 if you prefer to go that route.
Rock Auto Overflow
http://www.rockauto.com/en/catalog/f...ery+tank,10457
Do you know year model truck this came from??
Ken Cook is offline   Reply With Quote
Old 08-03-2017, 06:48 PM   #39
64shortbox
64shortbox's Avatar
I can't remember the exact model Ford the Overflow/Windshield Washer tank came from but the second generation Explorers about 1996 had them, my Wife's 96 Cougar had the same tank and the full size Ford trucks around the same era all used the same tank if this helps. I'm so cheap I even waited for 1/2 off days at the local Pick N Pull to get mine. If you have any other questions please feel free to ask.
64shortbox is offline   Reply With Quote
Old 08-04-2017, 01:26 PM   #40
The Rocknrod
Moderator
The Rockauto unit says right on the page: "FORD 1995 F-150 5.0L V8 Cooling System Coolant Recovery Tank"
Old 01-21-2019, 11:51 PM   #41
'63GENIII
'63GENIII's Avatar
Does anyone know if there is a certain cap that needs to be used on our radiators when an overflow reservoir is installed? I have a 13# cap with a lever on it (to release pressure it think). Im wondering if the pressure is too high for my cooling system?
I have a 4 core copper Harrison with the Ford overflow / wiper fluid combo (like '64 Shortbox). Seems that the coolant in the radiator disappears yet there will still be coolant left in the reservoir. Its as if the cap doesn't let the cooling system pull the coolant back into the radiator when everything cools off.
Never seems to run hot. 190 consistently. Can get 210 when towing and over 100* ambient but never boils. Running a 19" mechanical fan with the heavy duty Hayden clutch.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 01-22-2019, 09:48 PM   #42
damnyankee36
damnyankee36's Avatar
Yes the cap needs a gasket around the perimeter of the cap. Look #33 on the diagram above from Rocknrod. Any cap from whatever year they started installing overflow tanks on up will work.
damnyankee36 is offline   Reply With Quote
Old 01-24-2019, 12:43 AM   #43
'63GENIII
'63GENIII's Avatar
Got it. Thanks Yankee. Ill try and get a lower pressure cap (less than 13# anyway) and one with an upper gasket around the top of the filler.
Chris
'63 k15 long step
Old 01-24-2019, 06:23 PM   #44
damnyankee36
I don't think you will find a modern cap with the gasket and a 13lb rating. I would go to a 16lb anyway. It will help keep the coolant in the radiator instead of easily overflowing into the reservoir. It won't hurt the system.
I used to use a 20lb cap in my SBC Chevy for circle track racing. We couldn't use antifreeze so a high pressure cap was the only way to keep it from puking.
