Old 05-12-2017, 09:17 PM   #26
71rehab
Re: Clutch linkage adjustments
Originally Posted by 71rehab View Post
Good call. That gave me the length I needed to be able to shift smoothly and get it into reverse. Pedal needs to be on the floor though!
Now a day later, I'm back to square 1. Not sure why but now the clutch isn't fully disengaging again. What is that telling me? Lengthen the rod, new linkage , or is my clutch shot?
71rehab is offline   Reply With Quote
Old 05-12-2017, 10:04 PM   #27
geezer#99
geezer#99's Avatar
Moving the rod to the inside on the fork and getting some improvement should have told you you need a longer link rod.
Do the easy things first. Put on a longer rod. Adjust the clutch so the tob is about 1/4 inch from the clutch fingers.
Old 05-13-2017, 02:48 PM   #28
71rehab
Made it even easier. Added a 1/2" nylon spacer between the rod stop and the the knuckle that goes into the fork. Worked like a charm.
Also got the rod in case I need it in the future. For anyone interested in the future, 3/8" is perfect size. Anything bigger won't accept the knuckle.
Thanks for the help guys
