06-04-2017, 09:32 PM | #26 |
Re: New guy with a 69
Do the sleeve repair. It's cheap and it will probably work just fine.
06-04-2017, 09:49 PM | #27 | ||
My only concern is it seems the sleeve is a hit or miss fix. I'd rather fit it once instead of multiple times. |
06-05-2017, 09:56 AM | #28 |
and keep an eye on that lower radiator hose...if it sits on the lip of the frame rail it'll eventually saw its way through...better off with a molded hose than a flex ....
1970 short step c10 leaf spring 454 |
06-07-2017, 02:02 PM | #29 |
So I was doing some more research while I wait on parts to show up. Is it possible the oil leak is from the keyway if that didn't receive some permatex when this balancer was installed? I have still yet to pull the balancer as I want to wait to get the new one, just incase there is wear on the current one on the motor.
edit: nevermind, after thinking about it some more, and where the oil looks like it's coming through on the timing cover, not likely the keyway would be the culprit. Here's a snap of the truck the other day. Last edited by zachste; 06-07-2017 at 02:11 PM. |
06-07-2017, 02:27 PM | #30 |
I like the black fender splash guards.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
06-07-2017, 03:16 PM | #31 |
06-07-2017, 08:16 PM | #32 |
Just a sugestion but what year is the engine? Last year a friend had a similar issue. after replacing the pan gasket a couple times and quite a bit of frustration, we found out that the rubber gasket between the pan and timing chain cover is actually thicker for blocks newer than 78. At least I think it was 78. He got the correct gasket and no more trouble.
06-07-2017, 08:29 PM | #33 |
Who Changed This?
Pretty much sure that the leak is at the front seal, since there is oil on the timing chain cover above the pan gasket...if I understood that picture correctly. Before you pull the damper off, pull the oil fill cap and see if you have blow by. Yes, there shouldn't be any, but if there is, you're still probably going to have a leak. That would mean the rings aren't sealing. It's an easy and free check, though pretty unlikely to be the culprit.
BTW, that's a nice looking truck, even though I'm not into lowered vehicles.
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 06-07-2017 at 08:30 PM. Reason: compliment |
06-07-2017, 09:22 PM | #34 |
That's a great looking truck to start with. Now get that leak squared up so you can enjoy her!
06-07-2017, 10:28 PM | #35 | |
Still enjoy her in small spurts, but will be addressing the leak in the next few days hopefully. |
06-08-2017, 07:27 PM | #36 |
06-09-2017, 12:42 AM | #37 |
Nice truck!!
06-09-2017, 07:42 AM | #38 |
Good looking rig you got there!
06-20-2017, 09:59 AM | #39 |
Just wanted to follow up on this. It was indeed due to a groove being wore into the balancer causing oil to leak. New balance and seal installed and leak free since.
I do have an additional question I'd like some ideas on regarding the steering column. I have a vibration/rattle sound in the column, present over some bumps and even at idle in the steering column. Some of it is due to a worn gear selector lever and how it sits in the column. But I can put my hand on the column, on the cover right after the steering wheel hub/portion that tilts, and feel something almost rattling against the cover. I can post a picture if my description doesn't make any sense |
06-20-2017, 12:55 PM | #40 |
laying low
I felt sure you would find a groove in the damper. Thanks for posting your findings. It may help others.
There is an upper and lower bearing in the column. They may be loose allowing the steering shaft to vibrate a bit. There is also a large washer and spring to preload those bearings. It is located at the lower end of the column where the intermediate shaft bolts up.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
06-20-2017, 01:33 PM | #41 | |
As far as the steering column, can that washer and spring be adjusted without pulling the whole column? What I'm feeling seems to be higher up in the column. Last edited by zachste; 06-20-2017 at 02:30 PM. |
06-20-2017, 11:13 PM | #42 |
So it looks like this boot is ripped, but still some grease up in the joint. There is up and down and side to side play in it though. Is this normal for that joint?
06-21-2017, 12:24 AM | #43 |
laying low
I'm not sure just how much free play is normal in that joint. I would think it wouldn't be much. Can you grab the steering wheel and move it up and down easily? I think that big spring is in place but I don't see the large washer in that pic. I think I have a pic or two of how it should look. Lemme see. It should go together like in the pic. The first pic is a parts breakdown from the LMC catalog. The second pic is courtesy of one of our members.
06-21-2017, 08:23 AM | #44 |
It is a tilt column, with manual steering. No play up and down at all in the wheel or column yanking on the wheel.
06-23-2017, 09:32 AM | #45 |
So I'm thinking my column may be the "P" style. If so, then the washer wouldn't actually be missing, but the measurement from the bottom of the bearing to the bottom of that clamp on mine is not what the manual says it should be at. Mine measure roughly 1.75" as opposed to the 1.26" suggested in the manual.
06-23-2017, 10:50 AM | #46 |
laying low
The lower example is the C & K model pickups. The upper example is the P model. The only P model i am aware of is the P 10 step vans. Someone correct me if i'm wrong.
06-23-2017, 12:12 PM | #47 |
06-23-2017, 12:24 PM | #48 |
laying low
Anything is possible with vehicles this old.
06-23-2017, 01:46 PM | #49 |
06-23-2017, 04:56 PM | #50 |
laying low
I suggest you start a new thread titled "how to indentify my steering column" or something like that with pics of yours in cab and under hood. Im sure someone more familiar with them than me will pop in and help.
