#26 | |
![]() Join Date: Dec 2013
Re: C10 won't idle
#27 |
Re: C10 won't idle
Unfortunately that didn't work guys. It still won't idle
#28 |
Re: C10 won't idle
Have you adjusted the idle stop screw in so it will idle ? Just because it's a brand new carb doesn't mean it set right and ready to run out of the box
#29 |
Re: C10 won't idle
Yes I tried a million different setting so with same results. It came from natl carb factory set. Overall I'm really impressed with it. It's a great carb it just took weeks to get here. I'm gonna buy a new PCV valve tomorrow and clean out the intake fitting some more tomorrow hopefully it'll fix it
#30 |
Re: C10 won't idle
This is my truck. It's just an ole fixer upper. Lol and I was also just curious as to what this piece is. It sits under the intake in front of the carb. It swivels a quarter turn
#31 |
Re: C10 won't idle
thats your heat riser when cold the flap is open and directs heat to your intake manifold to help with atomization of the fuel until the truck warms up then the spring you see there on the counter weight relaxes from the build up of heat and directs more of the exhaust out to the tailpipe , see the pictures i posted above
#32 |
Post Whore
![]() Join Date: Feb 2016
Re: C10 won't idle
When you checked for the vacuum leak did you check all the intake manifold to the intake ports on the cylinder head for leakage? My AD's 235 occasionally has to have those bolts retorqued. That being said I suspect that your having a fuel supply problem. Start it up and and after it dies look down the inside of the carb and wing the throttle. You should see a good shot of fuel from the accelerator pump squirters. If not then remove the top of the carb so you can see how much fuel is in the bowl. If it is low or dry you have a bad fuel pump or a blocked fuel line.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 06-29-2017 at 09:57 PM. |
#33 |
Re: C10 won't idle
This may be way off base but sometimes dumb ideas trigger a good one. I was just looking at your pictuers again. The choke looks to be manual but not hooked up. You also said that if you place a rag over the carb then it would run.
Could this be as simple as the choke not closing and your trying to run it while it is cold and no choke? Can you just close the choke and try it? The symptoms as you describe are classic way too lean. Too much air, too little gas... What Grumpy is saying would cause this but the choke not closed would as well. Or maybe I'm just too tired.... ![]() Sorry meant what HO455 is saying...
72 Chevy C10 383/465 69 Corvette convertible 454/650 Last edited by Marine-58; 06-29-2017 at 10:41 PM. Reason: mis-stated something. |
#34 |
Re: C10 won't idle
Ok have to try it with the closed choke tomorrow and I'll check for vacuum leaks again. It isn't cold here in south Mississippi. It was very humid and around 80 somethin today
#35 |
Re: C10 won't idle
When an engine is cold, it just means not yet close to operating temp. Not necessarily that it is 40 outside. Until the engine starts warming up, it requires a much richer mixture.on .
BTW.. are you far from Keesler. Spent a couple months there back in 76 for TAD.
72 Chevy C10 383/465 69 Corvette convertible 454/650 |
#36 |
Re: C10 won't idle
No not at all. I'm about 15 miles from it @grumpy
#37 |
Re: C10 won't idle
Ok guys I did like y'all said and sprayed for vacuum leaks on the intake and there was one by the fitting where the pcv hose runs. The intake has a small gap. I'm gonna tighten it up
#38 |
Re: C10 won't idle
That's what it is. Thanks a million for the help guys. I'm gonna change the gaskets this weekend with my dad. Do any of y'all happen to know what exactly the gaskets are called? Intake gasket?
#39 |
Post Whore
Re: C10 won't idle
Good to hear you found the problem. It is called the intake manifold but if it is the same as my 235 it is also the exhaust manifold gasket set too. So be ready to have to pull the exhaust manifold too.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#40 |
Re: C10 won't idle
Your right it is. I bought it and I'm gonna change the valve cover gasket while I'm at it. It's pretty nasty. Having to clean the manifolds off gives me an excuse to clean my motor lol. It's pretty nasty lookin
#41 |
Re: C10 won't idle
Let us know how it turns out.
#42 |
Re: C10 won't idle
Alright guys after a bunch of cuss words and sweat we got it. It idles now. It still has a slight skip in it but we're gonna go back through the basics. Adjust the carb etc. we're gonna have to replace the PCV valve it's Rusted and almost crumbled.
#43 |
Re: C10 won't idle
Ok guys it'll idle but it's still rough. It still misses a little while driving. Sometimes it still stalls when slowing to a turn. I'm gonna have to order a PCV valve and try that out. The old one was toast
#44 | |
Re: C10 won't idle
This all can take time and patience. But when you are done, it feels good... ![]()
#45 |
Re: C10 won't idle
Ok guys thanks for the help so far I'm bout to go pickup my pcv valve. Just wondering what is the correct timing on my truck? I set it to 8 degrees BTDC. Is that correct?
#46 |
Re: C10 won't idle
I believe I fixed it. The PCV valve helped a lot. It stalled one time when I slowed to take a corner and still was slightly skippy. but other than that it ran great. Had plent of get up and go. Me and my dad advanced the timing a tad bit and adjusted the carb and now it idles a lot smoother. Thanks for all the help I appreciate it. Hopefully it'll still run as good tomorrow
#47 |
Re: C10 won't idle
Glad it is running better. Hope you and your Dad enjoy driving it.
