07-28-2017, 04:59 AM | #1 |
laying low
Re: Engine issue tap, tap, tap tap, tap, tap
Worth mentioning here is the mechanical fuel pump can peck too and sound just like a lifter. In my many years I have had two pumps do this. The spring inside gets weak on some allowing the slack at the pushrod causing the peck. Since the fuel pump is located directly under #2 cylinder it is easily missed as the cause. AC pumps usually last longer than others.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
07-28-2017, 10:37 AM | #2 |
I had the same issue and like Boog already wrote, it was a worn out fuel pump. After replacement the problem was solved. I did put in an edelbrock pump since my carb is also edelbrock.
07-29-2017, 11:54 PM | #3 | |
Who Changed This?
To the OP- use a stethoscope or a wood dowel and try to find the closest location of the noise.
08-02-2017, 02:26 PM | #4 |
I pulled the right rocker cover and see no evidence of any metal shavings. I turned the engine to #1 position and the #2 intake rocker is loose and there is way too much play in the push rod. I need to make sure the rocker stud didn't pull out, but my next step will be to pull the intake to get to the lifters.
08-02-2017, 04:30 PM | #5 | ||
Before doing all of that work, see how much it takes to pull the push rod out of the lifter. If its more than 1/8" then it is a collapsed lifter. You can't really see in there, but you can try. Maybe a borescope. You can visually see if the stud is pulled out. It's gonna be higher and there will be a witness mark at the bottom where it meets the head. Quote:
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC Last edited by demian5; 08-02-2017 at 04:33 PM. Reason: Poor spelling |
08-05-2017, 02:27 PM | #6 |
The rocker studs are all exactly the same height, so no stud pulled out. With the engine in the #1 firing position, #2 intake rod has about 1/8 to 1/4 up and down play. Rocker arms and tips look fine.
