08-25-2017, 09:30 AM | #26 |
Re: '53 3100
Nice progress!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
08-25-2017, 10:30 AM | #27 |
Re: '53 3100
Dang I just realized how slow I am going on mine. Nice build man.
09-21-2017, 04:48 PM | #28 |
Re: '53 3100
September 2017
2" front end drop turns into 3"ish drop... but I like it. Will have to change something - tires don't clear fenders when turning. Cut the head off one problem and two grow in its place... |
09-21-2017, 05:03 PM | #29 |
Re: '53 3100
September 2017
Radiator fan mount/install |
09-22-2017, 11:49 AM | #30 |
Re: '53 3100
Hey Robertjm711
I just found this thread...very nice job...love the 4 speed end of things too....not many standard transmission stuff on here..thanks for bringing us along...I will be following along.... MikeC
I am the squirrel... |
11-23-2017, 12:33 PM | #31 |
Re: '53 3100
Mid November 2017: Engine removal. Again.
Had to remove engine to pull pan and check crank to ensure it is a 5.3l vs a 4.8l. When I bought it last summer from a guy on Craigslist, I was told it was a 5.3l from a 2001 Silverado. Looked good and taken care of, even mounded properly on a pallet. He didn't have the VIN as he said he had already scrapped the donor truck. He only wanted the trans for his truck. So I took it home and started to clean and rewire the harness. I found injectors for a Flex-Fuel, and they didn't make a 5.3 Flex in 2001. (Second strike, one being no VIN). There are no external markings on these engines to distinguish, thanks GM. I then found a tab on the head gaskets the was stamped "4,8". Now I go into panic mode, strike 3. I texted the seller, and after a couple texts asking firmly for the VIN he would not respond. I looked at the top of the pistons through the spark plug holes and could see (~90% sure) dish top pistons that pointed toward the 5.3l. It was enough for me to install the engine for mock up but it has bothered me not having hard proof. Which leads me to now, removing the pan and checking crank casting numbers. Crank are 12552216, pistons are 12555820 and rods are 143, all 5.3l parts. Pan gaskets are not cheap, but worth the piece of mind. After all this I am confident it is a late 2002 or early 2003 Flex Fuel 5.3. I have read they started flex in 5.3's in 2002-2003 depending on source and started DBW in 2003.
It was said that if you cut off one hydra head, two more grow back. -Lernaean Hydra Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=743246 |
11-23-2017, 12:38 PM | #32 |
Re: '53 3100
Mid November 2017: Cleaning up fire wall.
While the engine is out I wanted to clean up the Swiss cheese firewall. It's pretty beat up so I don't think it will eve be show ready, but I am OK with that. I get better ever time I weld sheet metal, but still amateur. I'd rather it be sound and ugly than hiding problems with filler, fiberglass or spray foam (which I have found on this truck).
11-27-2017, 07:28 PM | #33 |
Re: '53 3100
Someone on the forum recommended these weld in plugs for filling the firewall holes. https://www.bobdrake.com/FordItem.aspx?Item=HR-1580
I just used a few to patch some holes in my firewall before paint. It will make the process much easier. |
12-30-2017, 02:21 PM | #34 |
Re: '53 3100
December 2017
Finished up on the firewall. Used some textured spray paint to hide some if the minor imperfections, not perfect but pretty good for a ~64 year old truck.
01-04-2018, 09:17 PM | #35 |
Re: '53 3100
January 4 2018
Installed clutch, hydraulic throw-out bearing, flywheel, etc. & transmission
01-04-2018, 10:57 PM | #36 |
Re: '53 3100
Very cool! Did you have to shim the T/O bearing?
01-04-2018, 11:09 PM | #37 |
Re: '53 3100
What’s the tire & wheel combo?
01-04-2018, 11:15 PM | #38 |
Re: '53 3100
Yup, the shims came with the bearing. Super easy.
https://www.summitracing.com/parts/h...IaAnAUEALw_wcB
01-04-2018, 11:20 PM | #39 |
Re: '53 3100
16” w/ 5” backspace and Venezia 225 60 16. With the S10 front/2.5” spacer and full width rear 12p axle I wanted the same rim/tire for rotations.
https://www.summitracing.com/parts/brw-997683450
01-05-2018, 03:57 PM | #40 |
Re: '53 3100
Just curious, how did you solve the rubbing issue with the tires?
01-05-2018, 04:35 PM | #41 | |
Re: '53 3100
Also I cut the springs to get the height and compensate for the common S10 lean, and I will get lowered springs to get a stiffer ride. There were many days with my tape measure, level and plum bob.
02-18-2018, 01:00 PM | #42 |
Re: '53 3100
January to mid February 2018
Straightened cab to frame and replaced bend hood hinge- hood wouldn't close straight. Installed plugs/wires/oil/filter, fuel tank/pump/filter/filler neck/hoses, fuel return bung to tank, radiator hoses, VSS signal generator, straight water neck/thermostat, built trans tunnel, computer re-flash, modified and installed handle receiver into Hurst shifter, trilled & tapped oil bung for gauge, battery box, power cables and air intake kit. All I need now to run is fuel hose clamps, fuel, coolant and some really good luck.
02-22-2018, 07:11 PM | #43 |
Re: '53 3100
Starting for the first time, I did have the MAF on backwards and the booster vacuum line open at first, and it turns out she didn't like that. After those tweaks, it ran just fine. temp came up, thermostat open as it should, good oil & fuel pressure, fans kicked on and no leaks (yet).
https://youtu.be/Cyg7r1fW-rM
05-05-2018, 02:36 PM | #44 |
Re: '53 3100
April 2018
Rebuilt 12 bolt passenger, installed 3.31 gears & carrier
05-05-2018, 02:37 PM | #45 |
Re: '53 3100
After almost 2 years, since I picked up a pile of parts on August 20, 2016, I have finally had the opportunity to drive my truck.
It was totally worth it. https://youtu.be/OMb15D_110g https://youtu.be/zwlxo6Rp0qs https://youtu.be/61BLek1f5Fk
05-05-2018, 06:40 PM | #46 |
Post Whore
Re: '53 3100
"whats he doing" love it.....congrats on getting it going!!!!
05-05-2018, 11:10 PM | #47 |
Re: '53 3100
Yes congrats, the best is the first drive...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
05-10-2018, 06:17 PM | #48 |
Re: '53 3100
out-freaking-standing! first drive, no feeling like it!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
06-26-2018, 01:09 PM | #49 |
Re: '53 3100
June 2018
Front & rear glass and wood bed
