Old 08-14-2017, 04:18 PM   #26
rsgt
rsgt's Avatar
Re: How to find why fuel gauge doesn't work?
Originally Posted by Freestate View Post
I'm going to piggy off of this thread as I'm having similar issues. I have not started diagnosing the problem but wanted to see if I could get some expert advice as to where I should start.
Issue: When the gas tank is full, the fuel gauge will read just barely over 1/4. As the tank gets empty, it will drop to 1/8. I've never let it get below that before filling. My first thought would be to check the float. Thoughts? Should I check something else first before pulling the float out?
Freestate, Mine was just like yours. Passed 1/4 tank when full then went down as gas was used. Here was the fix: http://67-72chevytrucks.com/vboard/s...d.php?t=744066
rsgt is offline   Reply With Quote
Old 08-15-2017, 08:32 AM   #27
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Originally Posted by demian5 View Post
Work smarter, not harder.
Pull the wire off the sender, turn the ignition on and ground the wire to the body. It should go to full.
High resistance equals more fuel and low resistance equals less fuel. Grounding the wire will give less resistance. I think you will find the gauge will read empty.
Remember, when the tan wire is off the sender the gauge reads past full because of the high resistance to ground AKA infinity between the wire and ground.
The temperature gauge works just the opposite, when you ground the sender wire the gauge goes to full HOT. Perhaps you had them mixed up.
I have done it myself, because they are so similar. VV
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-15-2017, 12:11 PM   #28
demian5
demian5's Avatar
Ah, right. i'll go back and edit. Yeah usually its the temp gauge people have issue with. Thanks!
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 08-15-2017, 12:34 PM   #29
Freestate
Awesome! Thank you for the tip. When I get a chance to do some diagnosing I'll let you know if that was the problem.
Freestate is offline   Reply With Quote
