Anyone else doing Ram Air?
Ram air set up I made from a gas can. Not sure how I feel about it? Thoughts? Does it look out of place?
Re: Anyone else doing Ram Air?
I like it.
Grandpa ![]() 1989 GMC K2500 1958 Alaskan Camper all original WORK : A necessary evil that finances what I really like to do. |
Big Block
Should bring in cool air. Looks good to me.
![]() Join Date: Jan 2001
Looks good. What's the intake tube made out of?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
thats pretty darned cool!
Old member
Cool sir! I like the fab work and the use of the gas can for the base.
More of a cold air though than ram air. Which are both better for the engine. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
There is some ram effect there in front of the radiator support (which is why the radiator works, too).
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#8 | |
Old member
![]() Quote:
Tube is Commercial 4" Flex duct, I used exhaust wrap to hide it.
Very nice.
Holy Crap! Look at that upper radiator hose!
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
At the body shop.
2010 ish silverado hose I believe
" That didnt make it any newer " " Dont antique the equipment " |
#13 |
![]() Join Date: Nov 2004
A "cold air" intake is typically an intake that's just been relocated to a cooler area under the engine bay. They usually pull in "dead air" that's surrounding them, but it's cooler air because it's farther away from the engine.
A ram air is forced air from the outside and because he went through the core support and is taking air from the front of the truck, I'd say calling it a Ram Air is fine and makes sense. The early firebirds (and even the late models) had Ram Air hoods that took air form the very front of the car. The air flow would be significantly different if he just put one of those snorkle intakes behind the radiator support. I like it, good job.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#14 |
Yeah, I didn't notice it at first, looks like a carbed (or Fitech? style EFI) on a 5.3. I thought it was a plain old 350 at first glance.
#15 |
![]() Join Date: May 2013
looks awesome , should work just as good as it looks
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#16 |
Old member
The cooling of the air is more important than the ram air effect if any on a carb or EFI system guy's.
A throttle-body-mounted air filter may look trick, but it ingests preheated under hood air from the radiator and the engine compartment. The best-running EFI cars breathe cold air from a front mounted inlet outside the motor compartment. The ram air effect doesn't even happen unless the vehicle is moving. How much depends on how fast your going. The whole thing is about cooler air though and that is what he has coming in, so he is good. Lot better than the guy's who just stick a tube over behind the head light with a filter under the hood anyway! Blocking off the filter under the hood from the rest of the area helps but it's nothing compared to true cold air. ![]()
#17 |
The "high pressure" area you refer to in front of the radiator... it's enough to move air through the radiator's huge surface area, but it's not going to supercharge your cylinders or anything.
In other words, you're going to pick up some power from the colder air, let's say 5hp. And you're going to pick up some 'boost' from the ram air effect, let's say 0.00001hp Of course I don't REALLY know what the numbers are, but the "ram air" effect is pretty minimal. It's not zero, but close. Nice fabrication btw!
#18 |
I believe the power increase for temp is 1% for every 10 degrees, or that's what I read. Let's say you drop the air from 140F ro 90F, that's 5%. On a 300hp motor, that's 15hp.
But my point was whether it's 5 or 15, it's a lot more than the ram air effect, that's all I meant.
#19 |
Very nice fabrication work, I like it a lot!!
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
#20 |
![]() Join Date: Jun 2002
Keith, I just realized your dad is Van Sizemore. I remember reading about his lightweight GTO in High Performance Pontiac back in 2003 or 2004. It's a great car with a heck of a story behind it.
I've had a few Pontiacs in my life, all I have left is a '79 Trans Am 400 4-speed and a 73 Firebird, but I dig the old Poncho's. Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
#21 |
I believe for every 20% you reduce air temp you can gain up to 6% hp if you do the carb/ injector mods/adjustments to match.
Stan 67 swb BLU MULE posted via flip-fone |
#22 |
Science it up! Use a multi tester and a cheap thermocouple to measure air temp under the hood vs in the intake system.
https://www.youtube.com/watch?v=tG8pjoe061k I'm a believer in cold air intakes, especially at the track. It's not uncommon to see underhood temps in the 130 degree range before a run and that's a power killer. I mainly fool with EFI and all that sort of data is available within the software.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
#23 |
BlahBlahBlah
To me I dont care about the semantics of whats going on with it. I think you did a great job and no matter what you call it you made something cool that helps not hinders your engine performance.
But after reading this thread if it was mine Id make a cool sticker to put on the wide black edge, something that is factory looking that says ... Ram Air for 67' or insert whatever your truck is.
#24 | |
![]() Join Date: Apr 2005
![]() ![]() I built this setup for the Farm Truck. I'm not sure how much HP I gained, but I know it reduced my IAT's by 15 to 20 degrees. I need to do something similar to my Suburban, but I've pretty much run out of real estate under the hood... ![]()
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 08-04-2017 at 08:33 AM. |
