Old 08-12-2017, 03:07 PM   #26
wesmigletz
wesmigletz's Avatar
Re: Spark Plugs What is wrong?
Just curious, you're running an Edelbrock carb. Are you still running a stock fuel pump, or a low pressure pump? Stock pumps put out too much fuel pressure.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 08-13-2017, 09:32 AM   #27
He has bubbles everybody.
I had a head issue I got through this time last year. I had a plug that was stuck, wrung it off flush, removed head(s), magnaflux found crack, better performance rebuilt heads, I'm a happy camper. Hopefully it's just a gasket for you. I guess my plug was rusted in from coolant. Truck never smoked and ran great till I broke the plug while removing to take the header off to access the brake line/hose union better. Talk about a snowball! Good luck!
Old 08-13-2017, 11:39 PM   #28
Steeveedee
Who Changed This?
Steeveedee's Avatar
Originally Posted by AussieinNC View Post
Do the spark plugs screw into the heads at 90 degrees to the head or are they angled off center ?
Taper seat or (peanut) plugs are meant for heads that have angled spark plug threads....if the spark plugs thread in at 90 degrees to the crankshaft, these plugs are the wrong type...they may be the same as what was in there, but that doesnt mean they are correct...
Post a pic of the side of the head showing the plug without the boot ....thanks
I'm pretty sure that beginning in '71, taper seat plugs were used on SBCs, and went straight in, not in angled seats.
~Steven
Simi Valley, CA
Old 08-14-2017, 10:05 AM   #29
greasemonkey
greasemonkey's Avatar
Apparently we're the only ones besides the owner that realize his engine troubles go a little deeper than fuel and spark.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 08-14-2017, 03:38 PM   #30
AussieinNC
Moderator
AussieinNC's Avatar
Yep...he has a constant bubble stream in the radiator...obvious water ingress into at least three cylinders...and an engine running like KRAP...
Pull the heads and take a look...
Post a pic of the heads once they are off...
Then we can all see what the issue really is...
Its a Chevy...its not rocket science...
AussieinNC is offline   Reply With Quote
Old 08-14-2017, 11:04 PM   #31
53chevyforever
53chevyforever's Avatar
Yes..thanks guys for all the comments....I am presently working on wiring....
soon will pull the heads...will let everyone know what I find...thanks...Tim
53chevyforever is offline   Reply With Quote
Old 08-15-2017, 12:00 PM   #32
snipescastle2
snipescastle2's Avatar
Talking Re: Spark Plugs What is wrong?
You can confirm the presence of combustion gases by having a shop place their emissions analyzer sniffer above the filler neck, if "HC" readings go up, bingo!
Not all head gaskets leak coolant into the oil, some leak into the intake passages. I'm surprised this engine isn't running hot....if you cannot maintain system pressure in the radiator, the boiling point of the coolant goes way up, placing a vacuum on water does just the opposite, lowers the boiling point.
That's why you keep a pressure cap on the radiator. 15-16 psi is normal, should raise the boiling point to 230-240 degrees.something like that.
You haven't noticed any unusual smoke/steam coming out from behind when you accelerate have you?
Hope it's an easy fix, I'd be looking for cracks in between the combustion chambers or maybe it's just a gasket issue.
Hth,
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 08-15-2017, 01:06 PM   #33
davepl
davepl's Avatar
^^^ This. I've used a buddy's SnapOn emission sniffer for this. I put it on CO (not HC, though maybe either works) and sniffed the filler neck, and even in a car where the leak was slight enough that there were no visible bubbles, the CO count would shoot up when placed over the filler neck.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-15-2017, 02:00 PM   #34
snipescastle2
I stand corrected! Knew it was one of the two!
Ben
