#26 | |
![]() Join Date: Jan 2016
Re: Ring gear bolts sheared off
#27 |
Moderator
![]() Join Date: Jun 2017
That bolt has been bottomed out and the carrier has been working back and forth against the threads...
see the mid area of the threaded section.... Did I see you were going to use 1 1/4" bolts ? I believe these bolts should be: Head Style: Hex Thread Size: 3/8-24 in. RH Underhead Length (in): 0.875 in. or 3/4"... not 1 1/4" I would be double checking the depth of the holes then add the thickness of the carrier section... I believe 1 1/4" will be too long... ![]() ![]() ![]() |
#28 | |
#29 |
Moderator
Ok...a 1/2" spacer is really thick...
Is there any way you can replace the gear set with a "thick 4.88 gear"... Adding a 1/2" spacer increases the leverage point against the bolt shanks...you can see the wear on the original bolt where the spacer allows the movement that will eventually break yet another set of bolts... Are the holes in the spacer plate elongated due to the earlier failure? |
#30 | |
#31 | |
Moderator
see : http://www.globalspec.com/learnmore/...asteners/bolts I have seen foreign knockoffs stamped the same that were below grade 5... The fact the threads on the shank are rounded off from the spacer plate tell me to suspect the actual grade... Have you considered changing the carrier out to a series 4? style over the current series 3 you have in there? |
#32 |
Aussie, So a series 4 carrier would eliminate the spacer even with a thin gear? I will check the thread depth to make sure bolts don't bottom out. The bolts I drilled out seemed soft and didn't have that sound of hard steel. Since the pinion and ring gear are ok, going to use ARP bolts for now. I am surprised this set up has lasted for 20+ years of tire burning and beach riding. Might change to all new correct parts this winter. THANK YOU for YOUR TIME AND INFORMATION! HAPPY TRAILS P.B.
#33 |
Moderator
Check out this website especially Tip # 12...
https://www.markwilliams.com/bulletproof.aspx You could use the original ring gear without the spacer if you moved to a series 4 carrier...assuming it is usable long term... Stay safe mate ! ![]() ![]() ![]() ![]() ![]() ![]() |
#34 |
I sell spacer deletes. 124.99 plus shipping. pm me. special hardware 34.99
ha ha ha ha ah. I think I wet my self |
#35 |
Just curious, this may have been mentioned already, but is this a true 12 bolt "Truck" carrier? They are different and that may have placed the ring gear bolts too close to the bearing cap/differential case causing them to shear off....just a suggestion.....
Ben ![]() P.s. If the passenger carrier was used, what happens is the ring gear bolts crash into the pinion gear, was there any scrapes/ gouges in the pinion gear at all?
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" ![]() “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” Last edited by snipescastle2; 09-07-2017 at 01:03 PM. |
#36 |
Hi Mike, Sorry if my dumb question made you wet yourself, I should have edited that part of the question ( it was stupid and funny at the same time )Well at least you got a good laugh out of it.
#37 | |
#38 | |
I saw the same thing happen to some contruction equipment. The bolts were not tightened properly and backed out. Its easy to tell what caused it. if you have the actual failed parts in front of you and a factual history of the rear. Its hard to tell what happend unless you can inspect each part carefully. I have had a rear end specialist do 3 rears for me, he always insisted that he would never install a spacer, better to get the correct parts to begin with. that belief was further strengthened when I saw the prep that needed to be done to the parts, including a spacer, to another rear that I saw being assembled. the mating surfaces of the carrier, the spacer and the gear all had to be deburred to an almost polished quality, otherwise everything would tourque up according to specification but the burrs and uneven mating surfaces would "crush" a bit and the parts would start loosening up and moving around. any wear on mating surfaces would reveal that. If the bolts simply loosened up and backed out specific and certain damage to the bolt and its head would reveal that. several other possiblilties. a reliable rear end specialist will be able to diagnose the fault. May be able to avoid it when the rear is rebuilt. Half off on those spacer delete's if you buy two ![]() Last edited by mike16; 09-08-2017 at 01:02 AM. |
#39 |
![]() Join Date: Jul 2015
All I can say is freakin wow man, that is some serious force to shred that thing!
