Old 10-28-2003, 12:05 AM   #26
Richard
I am about to place an order for this stuff, dont have the slightest idea how well it works, but sounds easier to work with and is a weld through primer. http://www.picklex20.com/ Seems to be a bit less costly than Por15 also. Below is the pricing thay sent me.
Thanks for your inquiry about Picklex®20. The price with ordering information is given below. All orders & shipping are done from our Huntsville location.
Price List :
16 oz = $21.90 + $9.00 (s & h) = $30.90, covers 200 sq.ft. on bare metal surface
32 oz = $39.90 + $11.00 (s & h) = $50.90, covers 400 sq.ft. on bare metal surface
1 gal = $77.00 + $12.80 (s & h) = $89.80, covers 1600 sq.ft. on bare metal surface
Note : Any ordinary plastic spray bottle can be used for spraying. The coverage shown are the estimate of application by simultaneously spraying and brushing by a paint brush. Only one coat is needed (on bare metal, the cost of the product comes out to be few cents per sq.ft.). Shelf life of Picklex®20 is more than 3 years after opening.
Prices shown are in US Dollars. The shipping charges are for inside USA and shipped by UPS ground.
Richard
Old 10-28-2003, 09:37 AM   #27
dmurphy68
I just sprayed por15 on my friends k-5 and then we put undercoting on top of it. It sprays well but stinks alot make sure you have lots of room. we put it to the test about a week later and many mud holes later just sprayed it off. put the truck on the lif and inspected the underside and nothing came off so i guess it will work. just my .02
Darren
The very atmosphere of firearms everywhere restrains evil interference. When firearms go, all goes, we need them every hour.
- George Washington
No free man shall be debarred the use of arms
- Thomas Jefferson
Later Darren
http://www.myspace.com/dmurphy68
dmurphy68 is offline   Reply With Quote
Old 10-28-2003, 11:10 AM   #28
70 longbed
I know this isn't going to help much, without the name, but before POR-15 I used this stuff from Autozone, Checkers, or any of the local parts stores. It goes on an off white, but as it cures, it turns black. you can paint over it, and it is a rust encapsulator. I will see if I still have some in the cabinet tonight and get you the name. I have used POR15, and you need to be prepared to do the whole area once you start. POR 15 does not stick to itself very well if you stop, then comeback later to finish, i.e overlapping the finished area; it will peel off.
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 10-28-2003, 12:23 PM   #29
krue
Designated A-hole!
krue's Avatar
70 longbed, that sounds like the stuff we called Vactan when I was in the Navy. That stuff worked great in the bilges of a submarine (which stayed full of salt water).
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 10-28-2003, 01:32 PM   #30
loweredd
www.loweredd.com
loweredd's Avatar
70 longbed, arent you supposed to sand the dried coat of POR-15 if you stop, then recoat?
loweredd is offline   Reply With Quote
Old 10-28-2003, 01:36 PM   #31
70 longbed
Good question! That may have made a difference, but I think that the POR is looking for that metal surface to bond to.
Keith
Old 10-28-2003, 08:58 PM   #32
JimKshortstep4x4
Talking
On the inside floors we prime with Rustoleum Rusty metal primer, (heavy coat so that it soaks in) and then seal the seams with butyl rubber.
Here is how it looks when primed.
Jim
Old 10-28-2003, 09:11 PM   #33
JimKshortstep4x4
Talking
For the finish coat in the floor we use Rustoleum Gray as it helps for seeing what you are assembling. This is a picture of a Burb floor as the primer is not dry on the cab. We brush the paint on coating it very heavy.
Jim
Old 10-28-2003, 09:21 PM   #34
loweredd
www.loweredd.com
loweredd's Avatar
OK, I just ordered a lot of POR-15 from wdz28 or I cant remember his name from UT......We'll see how well I can handle the process. I will be doing all the tinwork in my S10.
Old 10-29-2003, 02:36 PM   #35
meathead95
computer illiterate
meathead95's Avatar
what exactly is butyl rubber and where do you get it? what makes it so special?
thanks
keith
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 10-29-2003, 02:57 PM   #36
JimKshortstep4x4
Talking
Keith,
I will get the name of the material. It comes in a caulk tube and it is a roofing product for sealing seams. It is a very good product and will hold up for years outside. It cures to a soft pliable rubber and it sticks very well. It is paintable and it comes close to the original seam material that is on the floor so you can duplicate the bead.
Jim
Old 10-29-2003, 03:25 PM   #37
trinic
trinic's Avatar
I used Rust Encapsulator by...
Used Eastwood Rust Encapsulator.
Bought this kit:
Full Chassis Restortation Kit Black
item no: 10072 Z BLK
Price: $66.99
Turned out great. It's only being a few months since I did this, so I can't tell
you on the long term results. Goes on well with a brush.....
trinic is offline   Reply With Quote
Old 10-29-2003, 08:07 PM   #38
llama
i bought a quart of rust bullet on ebay. it goes on good but way to soon to tell if it works. just 2 coats and that is it. nothing else, like with the pors products. look on ebay you can save a few bucks buying on there.
llama is offline   Reply With Quote
Old 10-29-2003, 08:35 PM   #39
JimKshortstep4x4
Talking
Here is a picture of the sealant that we use. We refer to it as a butyl sealant, (it has butyl in it), but it is a polyurethane as can be seen from the pic. We get it through the industrial roofing suppliers. I am not sure where else it would be available.
Jim
Old 10-29-2003, 11:10 PM   #40
loweredd
www.loweredd.com
loweredd's Avatar
What about the seam sealer that hardens?
Old 10-29-2003, 11:22 PM   #41
Meathead & others....
Just finished reading a good article on this in the November 2003 of Auto Restorer. They did a test comparison between POR-15 ands eastwoods Rust Encaspulator...If I can get my scanner to jump start I'll post the article. It was interesting reading and I was kind of surprised at some of the comments. Both seem to work, but the author tends to go or recommend the Eastwood product.
Old 10-29-2003, 11:53 PM   #42
Hope this works OK to read. It is a 2 page article. If you have troubles reading it this size, PM me with an e-mail address and I'll send the ful size scan shots.
#1
Old 10-29-2003, 11:54 PM   #43
page 2
Old 10-30-2003, 12:00 AM   #44
jay-dawg
chevelito
jay-dawg's Avatar
here's my addy.
dvljr@wwdb.org
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 10-30-2003, 12:48 AM   #45
meathead95
computer illiterate
meathead95's Avatar
THANKS BILL,
COULD YOU EMAIL IT TO ME MEATHEAD95@HOTMAIL.COM
I HATE TO SEE THAT NOW, THE POR-15 SHOULD BE HERE TOMORROW LOL...........
72 2wd blazer
72 swb 4x4
Old 10-30-2003, 12:57 AM   #46
Primered_69
Primered_69's Avatar
please email me it @ michael_denise@hotmail.com
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 10-30-2003, 12:58 AM   #47
loweredd
www.loweredd.com
loweredd's Avatar
LOL meathead....me too. I should have mine Friday. I think that POR will have no problems though.
Old 10-30-2003, 12:19 PM   #48
jay-dawg
chevelito
jay-dawg's Avatar
got it thanks.
jay
Old 10-30-2003, 01:08 PM   #49
landon4421
Life is Good !
landon4421's Avatar
I am having my cab sprayed with line-x ! I feel that for the money it will be the best route for my 4x4 project. Rocks being flung up all the time ! I an also having the interfenders done also, and the bottom of the bed will also be done. My freind works at line-x and he is going to put a thin coat on for me! It will probally run me about $300 for everything !
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 10-30-2003, 06:39 PM   #50
Meathead and Primered 69
The emails were rejected by your accounts. I'm goinmg to try it again as too seperate ones in case they don't like those big graphics in one e-mail.
