#26 |
![]() Join Date: Jan 2015
Re: Lots of misc. 73-87 parts
I have a deal pending for these items, if anything changes, you're next in line. The studs are on slides, so will be able to line up with any hole spacing you may need.
#27 |
Chevy1966, sent you a PM. BUMP
#28 |
Chevy1966 and tkeduk8r, your shipments went out today! Bump
#29 |
Bed harness 73-83 or 84-91, for one ton with tailgate plug or otherwise?
Cruise servo brackets $20 Looking for upper dual tank harness from 88 R20. Looking for tailpipe hanger and tailpipes from 88 R20 chassis. Do you have 1991 454 TBI flex hoses?
83 K30 SRW 350 TH400 NP205 4.10 9' Fisher 85 K30 SRW 350 TH400 NP205 4.10 87 V3500 Dually 454 TBI SM465 NP205 4.10 9' Fisher 83 K2500 350 TH700R4 8600GVW Dual Tank 4.10 1973 Cheyenne Super 30 DRW Std Cab Z83 4.10 1976 Silverado C30 Std Cab 4.10 DRW (4 sale) |
#30 | |
#31 |
Hanger(s) have to be from gas/tbi one ton, both out drivers side. Also looking for nice exhaust heat shields, frame or bed mounted and the rear frame tips (just before rear most crossmember) cut off of one ton pickup.
#32 |
I have 2 of the tank selector valve/crossover from tank to tank harnesses. What one harness is lacking, the other one has. So selling them together, SOLD
I have a full set of 4 bolt on exhaust hangers, 2 driver's side, 2 passenger. The longer ones are identical, and can be used on either side on the rear. The stubby one is passenger side front, other is driver front. All have the oem bolts and isolators/clamps. Removed from a 1990 R3500 crew cab srw with a 6.2 diesel and TH400. These brackets are the same for the gas engines, just for the driver's side of course. $150 for the set. I forgot to check the tailight/bed harness, I'll do that later today. Last edited by Brennan; 03-12-2018 at 07:14 AM. |
#33 | |
Still got the mirror? How about $30 shipped to 85364?
#34 |
#35 |
#36 |
Hello, im looking for rear axle U bolt bottom plates.
14 bolt axle tube is 3.375 diameter. shipping to 19343 Thanks
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
#37 |
#38 | |
What did you find out on firewall to bed harness?
#39 |
![]() Join Date: Apr 2001
didnt see... could be interested in your tailgate one ton harness for me c30. any frame brackets for sway bar 2wd?
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
#40 | |
Also, do you mean front or rear sway bar frame brackets? I have the rear ones that were hot riveted to the frame. |
#41 |
do you have a 12 bolt posi for sale?
#42 |
![]() Join Date: Jan 2011
Did you ever sell the rolling frame?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#43 |
#44 |
Sorry, no more of these left. Also, the roller frame sold too.
New parts for sale: -Qty 3 BFG All terrain 33x12.50R16.5 tires with good tread remaining. Some minor cracking - $180 -Suburban overhead console- Gray, decent shape - $30 -84-87? upper and lower grille trim pieces - $20 -87-91 exhaust crossover pipe for small block engines (commonly used for dual exhaust head pipes) - SOLD -2 sets of 89-91 headlight bezels, 2 OEM GMC sets- $30 per set -OEM 89-91 GMC Grille, in great shape - $150 -Set of 3 aluminum wheels, 8x6.5 lug pattern, 16.5x10 - $20 -89-91 Chevy/GMC park lamp lenses , 1 left 2 rights - All of them together - $30 -Complete retrofit setup to convert cable style speedometer to VSS, (LS1 conversion, Diesel swap, etc.). Includes an OEM VSS 1991 suburban cluster, DRAC module w/ pigtail, "Diesel fuel only" fuel gauge, (cluster has gasoline gauge also), also will include a GPS style speed sending unit, which makes it a very easy swap to the electronic speedometer - even if your trans has no VSS sensor. Whole setup together - $300 -New center caps and lugnuts for Alcoa dually wheels, the lugnuts are special for use only with Alcoa , or alcoa style aluminum wheels. 9/16-18 threads for most GM or Dodge lug studs - $120 -C30 frame tow hooks w/ bolts - $20 -81-87 passenger battery tray, good shape - $20 Willing to make "bundle" deals if you buy a bunch of parts to save me the headache of showing tons of people. Will ship parts at buyers expense. Last edited by Brennan; 03-12-2018 at 07:15 AM. Reason: Sold items |
#45 |
More photos
STEERING COLUMN SOLD Last edited by Brennan; 03-12-2018 at 07:15 AM. |
#46 |
And more...
#47 |
And the battery trays...
#48 |
Pm Sent
#49 |
By chance any engine clamshell mounts
72 C10 SWB Stepper 350/TH400 (Sold) 70 C10 SWB Stepper 350/4SPD (CURRENT PROJECT) lq4 built, looking for 2wd 4l80 |
#50 |
