11-15-2017, 12:23 AM | #26 | |
Re: How do I kill this automatic function?
you might be lean because of the advanced timing. I think it calls for TDC with the wire disconnected. I think the computer advances it up to 42 degrees at light cruise?? I will have to open a bin file to double check. a few hundred knock counts is nothing to worry about. it is normalish. just starting the engine will cause some. What motor do you have? My TBI is stock at 9.4-1 |
11-15-2017, 12:16 PM | #27 | |
Doing more investigating and this engine does not have a knock sensor or the ESC circuit. So I think the knock counts are a BS number since this system has no way to sense for a knock. Looking at the logs it appears that the number just increments from 1 to 255 then resets. It looks like part of my problem may be a bad ignition module which is causing the Code 42. Ran through the diagnostic chart last night and ended with the result of bad module, so I have a new Delco unit ordered.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
