11-17-2017, 01:10 AM | #26 |
Re: Started My Never-Ending Project
On another note, I did receive my new transmission cooler lines today.
11-17-2017, 01:13 AM | #27 |
Yeah, I bit the bullet and went with the whole shebang. My budget is shot, all of the little things add up so quick. Lol.
Full top blazer or bust.... |
11-17-2017, 01:16 AM | #28 |
Same here, I always run into the "scope creep" issues with my builds.
11-18-2017, 11:15 AM | #29 | |
The only thing I didn't like is the space on the outside shifter paw, I can make a spacer but wanted to talk with him first. Any on have a contact number and name
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
11-18-2017, 12:54 PM | #30 | |
The contact number for J&b, (503) 749-3099. The space on the end of the shift rod I stuck a 7/16" jam nut that came with the kit. Is that what you are referring to? Or am I misunderstanding?
11-18-2017, 04:49 PM | #31 | |
Have a good day!
11-18-2017, 06:34 PM | #32 |
Spf 79, your design seems to be a bit different then mine, I'll have to crawl under with you pic to compare
thanks for the contact, I'll call Mon. Like the color, reminds me of my '62 Chevy Nice work, if the rest of your build looks that good, should be impressive
11-18-2017, 06:54 PM | #33 | |
I'm glad you like the color, I was on the fence when I first painted it. I was looking for a good match for the stock color and couldn't find anything that I liked. Flat red that didn't look pinkish apparently doesn't exist in my area, lol. So I went with the Rustoleum hammered metal "Sage" color. I'm happy how it turned out.
11-19-2017, 01:50 AM | #34 |
Finished cleaning the case and finally got some time to throw some powdercoat on it. All the aluminum parts I'll finish in a silver color.
May not be everybodys cup of tea but I really like the "silver vein" powder. |
11-19-2017, 10:53 AM | #35 |
I have a Hammerite paint sorta like that, always wanted to try it.
Looks good, but expensive... guy on here does his own, guess I buy the Wifey an oven for Christmas, That oughta go over big texture looks like a membrane
11-19-2017, 11:39 AM | #36 |
I have a set of pretty massive ovens that I use, wife was getting mad when I was cooking parts in the house oven. I love powdercoating though. Try to use my setup as much as I can.
11-19-2017, 02:02 PM | #37 |
Here's my oven. Made from a paint cabinet and 2 scrap ovens.
11-19-2017, 03:31 PM | #38 |
Nice! Whatever gets the job done I'm all for it.
11-20-2017, 03:05 AM | #39 |
That silver looks great on the case!
11-20-2017, 11:17 AM | #40 | |
What temps do you have to go to?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-20-2017 at 11:37 AM. |
11-20-2017, 11:24 AM | #41 |
Fumes aren't bad at all. I have mine out in the garage so no venting is needed.
11-21-2017, 01:06 AM | #42 |
Only have 2 more parts to powdercoat and I can finish putting it back together. Only get a few hours a week to work so it's taking longer than I hoped for but it's also my doing for having to coat everything.
11-21-2017, 03:43 AM | #43 |
Looks amazing!
11-21-2017, 01:15 PM | #44 |
11-21-2017, 09:13 PM | #45 | |
Pic of mine - it is not a threaded piece either. Question. What did you use to get your aluminum to polish up so nice? I spent a few evenings with a dremel and some polishing rouge followed by some Mother's compound and it came out maybe half as shiny as yours... Lol, afterward I clear coated it with some Rustoleum paint I had... I thought that the paint would prolong the polishing I had done. I knew I was not crawling under the Blazer at any point in the future to polish aluminum on a transfer case. Unfortunately the paint just turned the aluminum a dull gray.
11-22-2017, 12:25 PM | #46 |
It's actually powdercoat, it's called super chrome.
11-23-2017, 02:36 AM | #47 |
Cool! I did not know that you could get it in that color. Lol, totally thought it was an amazing polish job.
11-23-2017, 09:33 PM | #48 | |
11-27-2017, 03:15 PM | #49 | |
Now that the 205 rebuild is 95% complete, I am onto the TH350. The dip stick leak is an obvious fix and I already have a new grommet. I ended up attaching the transmission to the engine stand which is an awesome way to work on it and makes it very easy to spin around whatever way I need it. So drained the fluid out the removed dip stick hole and removed the pan. Next I removed the tranny filter and to my surprise, whoever worked on the transmission last managed to mess up such a simple gasket. I ordered a TRANSGO 350 1&2 kit and a summit billet oil pan. Should be here by weeks end. |
12-06-2017, 01:34 PM | #50 |
Well I managed to get the TRANSGO 1&2 shift kit installed and the transmission back into the truck. The flywheel was slightly bent looking when I turned the truck over with transmission removed so I picked up a new one of those as well.
While the transmission was out I did a quick compression test. The entire right bank of the engine all read 125 PSI and the drivers bank was a few 125, a 130 so I felt good with the air up here a little thin at 4300'. I finished up the NP205 rebuild and placed it on the jack and was ready to jack it up and remembered that the front drive shaft bolts are a pain and I would be 10x better to install the joint that connects to the transfer case before I fully install it. So I grabbed the front drive shaft and realized just how bad it looked. So I grabbed some new spicer u-joins from the auto parts store and started to clean it up. Now I am conflicted as to weather throw a coat of paint or possibly powdercoat it. I am just wanting to hear from some of you guys as far as if it will need a rebalance after I decide on what route to go with coating it. Also does this shaft normally turn with the truck in 2wd or only with 4wd engaged? |
