#26 |
Re: 1991 ccsb duramax
Good deal. The chop turned out nice and clean.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
#27 |
Bedsides almost ready for paint
#28 |
Under coated the frame and buttoned up the front end
#29 |
Built my own exhaust with some 3" mandreals
#30 |
More goodies for this weekend
#31 |
Lift kit installed! Still need to install crossover steering tho
#32 |
What did you go with for the lift? 4" or 6"?
#33 |
#34 |
Awesome build!
What are you going to put behind the Dmax? (Man/auto) What are your plans for the finished product? A service truck or ??? FtP
76' GMC K25 Sierra Classic Camper Special: propane powered 350ci/NV4500/205/D44/SRW 14B/4:10/tach,tilt,a/c - daily driver 77' GMC K35 Sierra Grande C/C: 350ci/SM465/205/D60/narrow 14B DRW/4:10 Flatbed 82' Chevrolet K30 C/C: 454ci/SM465/205/D60 Detroit locked/narrow 14B DRW/4:56 Flatbed, 6"Rancho, Alcoa's |
#35 |
![]() It looks pretty tall for 4", but I'm sure it will settle some.
#36 |
Count me in on this build. Have wanted to do one with a dmax myself.
Name: Les ---------------------- Couple 80s Couple 70s One 68 ![]() |
#37 |
Starting to install the crossover steering tonight!
#38 |
Cross over steering done
#39 |
crossover tend to be installed in the front hole . the rear hole is for high steer use .
watch out for them sh!tty cast aluminum shims sky jacker uses . i have had a few sets break out and fall out after just a few months . and 4" lift i would just remove them my self . helps keep the caster were it should be as dana 60 axles are a bit fussy on caster and death wobble showing up if its wrong . otherwise looking good .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
#40 | |
#41 |
Bed lines up perfect
#42 |
Nice work! What part of Alaska are you in?
#43 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Following along. Looks great so far!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#44 |
Subscribed.
Its looking good!! I have a similar Cummins swapped truck.
2006 GMC X-cab Z71 5.3LS 1994 GMC 1500 LWB 2wd 1989 Chevy Crew v3500 4x4 12 valve Cummins swap http://www.4btswaps.com/forum/showth...-for-feed-back |
#45 |
![]() Join Date: Apr 2009
lurk
1981 Chevy C30 440 Holmes 42K one owner miles |
#46 |
Time to clean up the front end! Repainted the core support and new led headlights and marker lights
#47 |
Where did you get the led headlights?
#48 |
#49 |
New led headlights look so much nicer
#50 |
the problem with most led headlight upgrades is SNOW / ICE driving .
there is no heater grid to melt them off . all the heat is out the back side not the front were you need it . i just did a full led upgrade on my work truck that takes 4x6 4 headlight system . all i can say is WOW worth every penny i spent on good units . . . j.w.speaker with heater grid . sad part is not offered in this tiny size for 89-91 quad light style tho .
