Old 09-25-2019, 09:21 AM   #26
A1971Blazer
A1971Blazer's Avatar
Re: 4 wire cruise switch
Originally Posted by ls1nova71 View Post
When you say "factory Blazer", you mean '81-83, not '72, correct? I assume you have one that looks like this.
This is a factory 4 wire switch that was used in the later trucks beforr they went to column mounted dimmer switch columns. It's the only NOS one I have ever had, and before anyone asks, no, it's not for sale.
I don't want to hijack...but I have that same factory switch...
blue, red, green, yellow
my LS1 (2002 F body) is DBC and I have the cruise module from the car
is there a link that shows wiring the cruise module to the pcm?
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 09-25-2019, 10:23 AM   #27
ls1nova71
ls1nova71's Avatar
Here you go. http://67-72chevytrucks.com/vboard/s...d.php?t=511477
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-25-2019, 10:42 AM   #28
A1971Blazer
Thanks!
1967 C10 Step side
1968 C10 Step side
Old 09-25-2019, 11:11 PM   #29
amcgeh01
amcgeh01's Avatar
Thanks LS1,
My mechanic friend has it currently so I will pick it up in a few days and take some pics.. I also located a highly referred steering column specialist in Anahiem named Felipe of OC Steering and he says he has all the parts I need to make this work.. My friend discovered the bearings are shot so it may need to be rebuilt a the same time.
Can you post a pic of what you have? If it's a GM column it should work.
In-work on my 5.3L/4L65E/NP208 case conversion into a 1972 GMC JImmy 4x4... Not as simple as it looks folks..
amcgeh01 is offline   Reply With Quote
Old 09-26-2019, 07:03 AM   #30
ls1nova71
ls1nova71's Avatar
If your lever looks like the one A1971Blazer posted in post#26 then it will work, however most of those levers are only 3 wire and need to be converted to 4 wire.
Old 09-26-2019, 08:09 AM   #31
A1971Blazer
This was from your old post...but do you happen to still have any of these labels?
1967 C10 Step side
1968 C10 Step side
Old 09-26-2019, 10:03 PM   #32
ls1nova71
ls1nova71's Avatar
Attachment 1942695
Yes, I still have them, but your lever looks pretty nice already? PM me if you want more info on them.
Old 09-27-2019, 07:32 AM   #33
A1971Blazer
Now that I look more closely at mine...you're right..it's pretty good
putting it on a 50 year old truck...it might look out of place with a nice bright clean label
Thanks for your opinion and your help...!
1967 C10 Step side
1968 C10 Step side
Old 09-27-2019, 11:01 AM   #34
ls1nova71
ls1nova71's Avatar
If you're restoring the whole truck then it may be worth it. In order to use them though, you need to paint the lever black so it doesn't show a difference in colors between the decal and the plastic. I use single stage enamel with gloss hardener and it's dark enough that you cannot tell that it is a sticker, but have put one on an unpainted lever and it looked terrible, way to obvious.
Old 10-01-2019, 04:46 PM   #35
hemi43
hemi43's Avatar
Originally Posted by amcgeh01 View Post
Hi All, really nice to see so much info but apparently my steering column is different.. It's a tilt but when I looked at the turn signal to pull it out, it does not have the set screw that I see in the pics posted, mine screws in...? Does that mean there is no way I can get my mine to work with cruise control for my 5.3 Vortech…? I sure hope I don't have to look for another steering column...
PM sent !! You didn't mention what year engine you had.
hemi43 is offline   Reply With Quote
