Old 12-27-2017, 12:27 AM   #26
Holzy
Re: Relocate gas tank
Used a tank set up from LMC with side fill. Going to run it to my bumper and have the licence plate flip down and expose the filler. I have the original step bumper so should be somewhat easy.
Holzy is offline   Reply With Quote
Old 12-27-2017, 04:53 AM   #27
bbrriiaann1973
Cheapest? 5 gallon bucket in the bed with a hose to the fuel pump! Remember you said cheap
bbrriiaann1973 is offline   Reply With Quote
Old 12-27-2017, 01:01 PM   #28
Devil Pup
Devil Pup's Avatar
Originally Posted by kamkam1 View Post
Devil pup, will that tank work on a coil spring truck? I measured my frame today and it’s not wide enough or long enough. The tank measurements are 29”x29”x 11, according to the specs on the tank from amazon. Thanks Kirk
Best of my knowledge the frames are the same. You can bolt leafs onto a coil frame and vise versus if I recall correctly. I had to remove the spare tire carrier bracket as well as move the rear cross member back in order for it to fit. the width I didn't have to change. How wide is your frame opening from side to side?
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388
Devil Pup is offline   Reply With Quote
Old 12-27-2017, 01:13 PM   #29
cardude
cardude's Avatar
Thumbs up Re: Relocate gas tank
Absolutely Beautiful install!
I'm SO planning on doing this!!
Got the tank on my Amazon wishlist for next year!
Originally Posted by Rufas View Post
Here is the typical round door setup installed on my 70 GMC.
cardude is offline   Reply With Quote
Old 12-27-2017, 02:34 PM   #30
Mave
Cheap not dumb
Mave is offline   Reply With Quote
