#26 |
![]() ![]() Join Date: Jul 2002
Re: New year, new body 70c10 to 86c10
Truck looks good. Enjoying the build read.
#27 |
#28 |
Bumper update:
Ended up taking around 4" total off the length. Now it hugs the fenders and lines up with the light bezels. Put it in place to get a good look at it, but its not mounted yet. Also, made my first cruise night...excited with how everything is coming along and the feedback has been great. |
#29 |
Had a minor scare when my welder died. Found it was just a switch, which was an easy swap and we are back in business. Once I had the bumper up in place, its short profile exposed some of the front frame rails. Played with a couple different ideas to cover it, from extreme 70's/ 80's z28 style wedges to thin profiles and settled on kind of a mixture of both. Used 3/16" rods to hug the valance and create a nice lip on the lower section. Time to mud and paint.
#30 |
Got a little side tracked with some parts that came in to dress the engine up a little. Got some billet coil brackets, new coils and some plug wires. The coils are basically OEM, just have a red plastic casing. Cleaned up the wiring and had to use some stainless spacers to hide them the best that I could.
#31 |
I love the tweaks to the bumpers!!!! Everything is looking great!!
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
#32 |
Very Nice! Good stuff here!!
Just a Hillbilly in the Hood http://67-72chevytrucks.com/vboard/s...d.php?t=622194 |
#33 |
Progress on the bumper and keeping with my M.O., several other things.... Got side tracked again, when I came across a 73' grill on CL and decided to go a little further back in time with the front of the truck. I knew there would be some modification, but didn't want to get that crazy with the latch and hood pin. So here is what I did.... The side mount brackets were easy, there was already (2) indents on each side to indicate where to drill for mounting bolts. The center support however was a little different. To make the new support mate up with existing latch system, I had to cut it and splice the new with old. Also had to bevel the back of the grill a little to allow it to sit flush. For the bumper, I originally wrapped it black because down the line I was thinking of doing a black hood and maybe the wrap would hold up better from chips?. By doing this, I felt it hid the features I changed and now I'm in the process of painting it silver. We'll see how it turns out...
#34 |
Some updated pictures of the bumper finished. Ended up painting it silver and doing a satin clear coat. Mounted with stainless hardware and brass wing nuts. Main reason was I didn't trust my welds to do it concealed and I like being different.
#35 |
Dude! I dig the wing nuts!
#36 |
Couple more pictures....
I know its Fords idea, but I love the Raptor style lights and have put them on all my trucks. Figured I follow suit. Note to self, try the lights before you install!!! there was one rouge red one in the mix. Will have to remove trim/ grill again. Lesson learned. |
#37 |
#38 |
Some pics of the new rims and tires. Did like the old school slots I had on before, just wanted to go a little bigger. Didn't realize how hard it was going to be finding tires though. Seen a set up on a Camaro that looked good, but when I put them on my truck; they looked like roller skates. Ended up going with 16 x 8 powder coated Steed D rims with BF G-Force 255/50R16's upfront and the biggest I could find Toyo poxes 275/60/16's in the rear. Also installed 1-1/2" spacers to push them out a little.
#39 |
Looking good!!
#40 |
Was looking to get to the hood next, but I'm having a hard time finding one by me. While the search continues, figured I'd do something with the exhaust. Still keeping on a budge, a friend of mine had a full OEM 3" exhaust from an unknown truck that I'm able to cut up and make work. Picked up some glass packs and X-pipe from Summit and got to work. Was firm on going through the body with the exhaust, but couldn't follow though when I got to that point. Ended up just dropping it out the bottom side for now and I'm going to make a custom tip to hug the body.
#41 |
Thinking of getting a little crazy with the tip. There is so many things that have been done already and I want to stick to the "Custom" theme. Have a set of old headers and a valve cover, so here we go.....
Here's a rough sketch of what I'm thinking. Going to try my best to not make it look too Mad Max. |
#42 |
Welcome to the Thunder Dome!!! Once I had everything tacked, I realized that not all ideas are good ideas. Going to get some boring standard tips for now and put this one on the back burner.
#43 |
Productive weekend. Dropped the rear a tad more with 2" drop blocks ( It already has a flip kit ). Noticed the last owners handy work with one of the shocks that didn't fit against the frame, so I guess he cut it? Figured while I was there, I might as well replace both. Also added 4" black tips to the exhaust for now. Got everything in and 2 hours of quality time of cruising.
#44 |
Looks sick.. stance is on point! How’s the 5.3 running?
#45 |
Second that.....love the stance!!! Mike
#46 |
Running strong. Sound mean with the 3" piping and the glass packs. Got new plugs, still working on the right coils. Everywhere I look says to just use stock. Was thinking turbo? Will have to do some front suspension work before I put more power in it.
#47 |
Great looking truck. Pretty close to where mine is headed, both appearance and mechanically. We even have matching red hoods right now!
Love the black exhaust tips as well. |
#48 |
Thanks! Checked out your thread and they are pretty similar, I'll be sure to follow your build. Looks like you are truckin' along and have a plan, good luck!
#49 |
Really... I’d say run stock! How big of a turbo are we talking?
#50 | |
