01-03-2018, 12:43 AM | #26 |
Re: Reproducing missing SPID
01-03-2018, 02:35 PM | #27 |
01-03-2018, 04:00 PM | #28 |
Thanks to Jon who sent me a bunch of Fremont build and option sheets I am able to get a little closer to having an accurate reproduction spid created.
One more question, should the V37 Custom Chrome option also be listed or is it included in Z61 option? Since the A/C is dealer install Ill just leave the bumper guards and tow hooks in that group as well. Here is the latest Last edited by 1966 K10; 01-03-2018 at 04:24 PM. |
01-03-2018, 06:28 PM | #29 | |
See : http://67-72chevytrucks.com/vboard/s...&highlight=z20 |
01-03-2018, 06:34 PM | #30 |
My '66 Fremont Sub has a different approach to the 3rd seat option:
01-03-2018, 08:49 PM | #31 |
Yes the carryall lived its whole life in NV so had conversion done.
Does anyone know what order these options are supposed to be listed? In 67-72 spids they are alphabetical but the 66 spids seem to be all over the place even from the same facility. VH, why the different code and wording on your C1466? anything special about the seat? build sheet? I just saw this spid for a K1466 and am more confused than before. |
01-04-2018, 02:08 AM | #32 |
01-04-2018, 08:34 AM | #33 | |
The SPID you posted is not from a Fremont truck. That may be the reason for the different wording/coding. |
01-04-2018, 12:41 PM | #34 | |
9838 is Panel type driver seat replacing standard suburban seat or Supplementary seat 9868 lighter not available with custom comfort or custom camper 9842 armrest RH door , LH door not available with custom comfort option. Like to see exactly what this all looks like ???
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
01-04-2018, 01:52 PM | #35 | |
Edit: I was going to delete this post since I see the info is already covered. I'll go ahead and leave it here in case the different phrasing is helpful.
K Quote:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-04-2018 at 02:14 PM. |
01-04-2018, 09:39 PM | #36 | |
Regarding the seats. I assumed 9838 was related to the Third Row Seat. The truck has sliding windows in the rear and I thought that was part of the 3rd Seat option. When I got the truck the 2nd & 3rd seat was missing. The story is that a California Mental Hospital originally ordered it and used it as an ambulance. It seemed odd that you would order a 3rd seat knowing that it would be removed. Anyway, the front seat was still there and appears to be all original except for the recovering. In the '90s it was transferred to a nearby Ca State prison and used by the Maintenance Dept. They promptly spilled lots of paint and paint thinner in the rear. All of the receptacles for 2nd & 3rd row seats are in the floor. Other modifications were done in the rear for either ambulance or painter duties. Regarding the armrest. It had LH only. Regarding the paint. The Trim tag says "SPC". It was re-painted blue in the '90s. The original color is white and I have never understood why it is "Special" because it is remarkably similar to the normal "521 White". |
01-04-2018, 11:27 PM | #37 |
Was able to get to the block stamp after 2 cans of gunk and 2 cans of brake cleaner. Looks like the RR in the door jam is the engine replacement. What I dont understand is how it could get that filthy after only 5K miles. Heads are also blue but oil stained darker. They reused the valve covers, manifolds, carb etc.
T0406R is a 327? Head marks are a single pyramid which looks like 283 PP? Its seized good, the damper moves 1/4 inch in all directions, is it a press on or bolt on? So much grease there is no gap between the cross over pipe and the oil pan. I guess dusty roads and leaks from every gasket will give you 1/4 inch of "insulation". Pulled the DS valve cover in an attempt at getting to the rear casting numbers but looks like Ill need a gallon of solvent to get all that crap off to get to them. Gave it a comet bath, installed the horn button and fogged the wheel. Actually looks blue now not silver. |
01-05-2018, 10:25 AM | #38 | |
Under the Special Equipment section for JUST Suburban it lists 9838 as a "Panel truck style seat". Now go to the Pickup truck and Panel section ( thats how the Data book has this listed) of the Special Equipment section and it lists the same 9838 but says "Carryall Front + Auxiliary" seat or normal Suburban front seat available for a Panel truck . Same number just different meanings under different categories. The lighter and the arm rest still have me confused. Im guessing here, that the arm rest was a different design or color than normal. The description is saying RH and LH are both available under that 9842 code , you just order TWO 9842s. The lighter ? Baffled . Cant figure out what would be "Special" here. In these two pictures of my 66 GMC K Panel you can see the Suburban seat with the Panel truck seat holes plugged with that phillips screw.
01-05-2018, 10:36 AM | #39 | |
01-05-2018, 10:55 AM | #40 | |
Completely different subject but one you especially could clear up. A while ago there was a pretty crazy thread about a special 1965 and a half (1966) 327 truck. Owner has claimed it has an L79 with a roller cam. Also on Facebook I ran into another guy that stated " If you had enough money , you could get ANYTHING you wanted back then " He claimed he saw an original 1966 Short Fleetside with a 396. He sited his evidence from "watching and studying Barret Jackson" ( his words) . Others here have claimed something similar " A neighbor told me you could get anything you wanted back then " . . I realize there were some "Skunk Works" or prototype vehicles made. But a vehicle moving down an assembly line or a vehicle outfitted with an L79 in 1966 that was not suppose to ever get an L79 ? I do have a legitimate story from an original owner who worked at the Jainesville plant that followed HIS 1968 L72 Biscayne down the line, as it was being built, where they did add extras , mainly because he was friends with these guys but it wasn't anything extreme like above .This "You could get anything you want back then" statement has grown into its own legend now. Anything was possible ! Hope you can shed some of your expertise on the subject please.
01-05-2018, 12:51 PM | #41 |
Moderator
Even it wasn't built yet for 20 years? (L79) See this is where you loose me on that story. No roller cam 327 ever was made, and a roller cam small block started in like 87? or latter.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 01-05-2018 at 12:59 PM. |
01-05-2018, 01:18 PM | #42 |
I really dont want to debate the roller cam again Rocknrod but the L79 was used 1965-1968 but was just a normal hydraulic cam
01-05-2018, 01:22 PM | #43 |
Moderator
Oh.
01-05-2018, 02:22 PM | #44 | |
01-06-2018, 12:47 PM | #45 |
Another reason to think the A/C was Dealer installed is that the heater control face and center duct are Fawn, not matching the 'brown" on the the rest of the dash. The textured brown was used on '66 only.
01-06-2018, 01:27 PM | #46 | |
Around '66 exhaust emissions became a big deal, starting with California. Then the factory was required by law to certify that each engine/trans/axle combo met emissions requirements. As you can imagine that is very expensive and one reason for the great deproliferation of powertrains. Emissions requirements and Fuel Economy standards became more and more restrictive. So it became more increasingly difficult to get "Factory" special engine combos. Also the Dealers became gun-shy about making those swaps. Back in the day things were very different, but bulletproof documentation is the still the only way you will convince someone of it being more than legend. Some things were available, but not anything you wanted. |
01-06-2018, 01:52 PM | #47 |
So, in the one case where an original buyer states his truck came from the factory with an L79, it MAY have been possible, but it would have taken some inside string pulling and purposed effort on his part to get it done? In other words, he should know exactly how it got there, right?
01-06-2018, 03:38 PM | #48 |
I am very familiar with the L79 Corvette engine. That would not have been a trivial swap for a vehicle assembly plant. Would have involved A LOT of string pulling. So much that you would not forget it.
A swap involving something that assembled exactly the same as normal production was more do-able. In other words if the difference is completely internal. That's it. I'm tapping out of the L79 roller cam discussion. |
01-06-2018, 03:49 PM | #49 |
Moderator
Since they (GM) didn't make it for another 20 years so the answer is obvious.
01-06-2018, 06:07 PM | #50 | |
