#26 |
Re: New Member, New Truck
#27 |
That's nice Rufas!
1971 C10 LWB, 2WD, Cheyenne, 350/350, ps, pb, front disc, 5 lug, 12 bolt posi 1973 Short Bed, Salvage, needs a lot of work 1978 Stepper (sold) 1977 Blazer, 3/4 ton axles, 383 (sold) 2004 GMC Sierra, Crewcab, Duramax 2014 Chevy Silverado Crewcab 5.3 (sold) 2019 Silverado Crewcab LTZ |
#28 | |
![]() Join Date: Oct 2009
Since you confirmed you have 16.5 tires, it’s important to confirm your rim now. I’ve never seen 16.5 5 Lug wheels. Has anyone else? i may just not be aware. But your truck came with 16 inch 5 Lug rims. Need to confirm anyway. It has happened before - someone puts a 16.5 Tire on a 16 rim - a big safety no no. Last edited by jocko; 01-05-2018 at 11:43 AM. |
#29 |
Very cool truck. Love that 505 dark green and swing out bumper.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
#30 | |
If I remember correctly from late 70's or late 80's but used on multiple vehicles. The good part is you can still buy spray touch up in this code. I've purchased these from Napa and Advance Auto. I used these spray cans to paint my replacement steering column and touch up some things on the truck. Match is almost perfect. This is a can of original touch up with the complete paint code from GM. Not the touch up from Napa. The WA 8774 is important to get the correct paint. ![]()
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
#31 |
That bumper is super cool. I need more pictures! cool find.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
#32 |
That is a GREAT truck, nice find! I'd freshen the interior and fix anything mechanical and roll with it. Keep the bumper!
#33 |
More pics;
The good, the truck has one of the nicest grills I have seen, it looks almost new. The side moldings are also very clean, only the two lower moldings behind the rear tires and the tailgate band need to be replaced. The body I think has one dent in it that I can find. The Bad; The rust I found that needs to be fixed. Not to bad for a 46 year old truck, cab corners look good. I thought it was an original paint job, it's not.. I think just the front has been repainted. Oh well, makes me feel better when I weld up the holes in the doors from the mirrors. PO put sheet metal screws in the upper molding on the drivers side bed.... A couple tips I have found on the sight that I found super helpful; my hood didn't pop up, found a tip to adjust the back of the hood hinges down and man that worked like a charm. Working on getting smaller mirrors to work found a tip to get more adjustment from the RH one, will be trying this soon, not a fan of the big camper mirrors PO put a Holley Economaster carb on, I guess I'll be saving up for some kind of fuel injection. OP also put a aluminum 2 core radiator, looks nice, hope it can keep up. Painted the valve covers and I'm installing the HEI this weekend. Valve covers came out nicer than I expected. Thanks for all the great comments and all the great tips!!
#34 |
Florida Edition
![]() ![]() Join Date: Oct 2010
Excellent purchase regardless of price! Congrats.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
