Old 02-01-2018, 06:32 PM   #26
bbrriiaann1973
Re: 255/70/15 rears, ?????? For the front
10 inch front
13 inch rear
Brian Ritter
bbrriiaann1973 is offline   Reply With Quote
Old 02-01-2018, 09:29 PM   #27
CST10
CST10's Avatar
Originally Posted by Mike C View Post
Here is my '69. It is a leaf spring truck that is flipped in the rear for 7" (7 1/4" as measured from center of axle to bottom of wheel well) with 275 55 17 on 17x9 5" backspace (zero offset) wheels.
Front is 2 1/2" disc conversion spindles and 2" drop spring for 4.5" drop. Fronts are 235 55 17 on 17x8 4" backspace (also zero offset) wheels.
I am THRILLED with the 17" rims and would do that again. In the rear I switched to the 71-72 wider axle housing to get right spacing for the wheels. I think they have plenty of rubber with the 55 series.
My opinion about which trucks look the best are that they didn't do too wide a wheel/tire combo in the front. And I like a little rake as well.
Nice stance indeed.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 02-01-2018, 09:31 PM   #28
CST10
CST10's Avatar
Originally Posted by miller6t9 View Post
not the best pic, but this is my truck with approx a 4/6 drop and 235/70/15 front and 255/70/15 rears
That drop is only 1” lower all around.
Looks good and give me an idea what mine might look like.
MyToys:
Old 02-01-2018, 10:06 PM   #29
miller6t9
miller6t9's Avatar
its probably more like a 3.5/5 in that pic....that was taken before i got the Hotchkis springs on it...hope it helps
miller6t9 is offline   Reply With Quote
Old 02-02-2018, 01:49 AM   #30
cleanfreak
cleanfreak's Avatar
I don't have any pictures handy , my 68 had 255 70 on 8" wheels on the rear with 235 75 on the front , on a 7" wheel though , looked right. 235 70's on your 8" wheel should be right on for the look you describe , look forward to seeing it. Always thought this truck would be more perfect with a bit more front tire. The picture on my profile is not the 255's , both smaller.
cleanfreak is offline   Reply With Quote
Old 02-03-2018, 06:08 PM   #31
CST10
CST10's Avatar
Thanks for the info. Appreciate it. I’ll post some up once I get em on it.
MyToys:
Old 02-07-2018, 04:17 AM   #32
hdff
hdff's Avatar
255/70/15 on all corners with a 2/4 drop on 8” rims. Going to 275/60/15 on next set with 10” rims on the back
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 02-07-2018, 09:35 PM   #33
CST10
CST10's Avatar
Very sweet truck you have. I like the stance too. I thought about 255/70’s all around but I want to keep a little rubber rake stance if possible.
MyToys:
Old 02-25-2018, 09:01 AM   #34
BugzC10
BugzC10's Avatar
Which tire did you finally decide on?
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 02-25-2018, 09:07 AM   #35
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Keith, did you just change the springs for your drop?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-01-2018, 11:23 PM   #36
CST10
CST10's Avatar
Think I’m go with 235/70’s on the front with 8” wide wheels. It will give me a little rubber rake but fill the front well some.
This truck has the same tire combo. Looks great.
MyToys:
