#26 |
![]() Join Date: Jun 2019
Re: 4L80E - column shift
A great video how to use your current shift linkage "stuff", can be seen here:
https://youtu.be/jh7UkYNqVqk I plan to do this to mine when I get to the 4L80e transmission.
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 |
#27 | |
![]() Join Date: Dec 1999
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#28 |
![]() Join Date: Mar 2015
I am doing a little guessing here as I haven't measured the indicators myself.
I believe the indicators with the extra gear are embossed into the same space as the three speed automatics. If you just relocated the stock linkage, to fit the 4 speed, it will be off. If you use aftermarket linkage the ratio is adjustable at the transmission shift station lever. This makes the alignment possible but slightly more difficult shifting as the spacing is so close and the shift effort is slightly higher. My preference is the stock indicator (1-3). With 1st gear, of the 1-4, off to the right far enough it is barely or not a all visible. If you have the electronic overdirves it really makes little difference as the full throttle shifting rpm is programmable and no reason to shift it yourself. Others not familiar with the truck's shifting have no issues getting it in gear. Even if the pick first and get second it's not a safety issue. It come down to "Oh you have an overdirve" when they spot the indicator on the column. Cheers |
#29 | |
![]() Quote:
#30 | |
BMW & ASE Master Certified
Im using factory 87 tilt column, factory 87 linkages, moved the linkage pivot part 1 hole forward... ill take a picture , but its just a rectangle 3/8 aluminum plate with 3 holes 1st bolt hole goes through aluminum plate and frame 2nd bolt hole goes through stock shift pivot bracket, aluminum plate and frame 3rd bolt hole goes through stock shift pivot bracket and aluminum plate
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
#31 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#32 |
the only detents in the column are the P-N-R spots. past that its open. I have lokar style straight linkage on my 4l80 in the 71 and it works great. D is were its supposed to be. 1st is just lower down than the indicator.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
#33 | ||
![]() Join Date: Apr 2005
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
