Old 02-06-2018, 11:39 AM   #26
bmfm64
bmfm64's Avatar
Re: New brakes suck
Originally Posted by Trackman101 View Post
Does this motor have a cam? How much vacuum does it have?
Yes it has a Z06 cam installed in it but nothing out of the ordinary. I have not measured the vacuum but all the forums I've read on the swap there has been no issues with vacuum.
bmfm64 is offline   Reply With Quote
Old 02-07-2018, 12:44 PM   #27
bmfm64
bmfm64's Avatar
Re: New brakes suck
I re bled the brakes again last night and no difference....
Old 02-07-2018, 01:24 PM   #28
Keystone_Hate
Re: New brakes suck
What was the original bore size on the stock MC? If it was different from what you're running now, which I believe you said is a 1" bore, that may have something to do with it.
Keystone_Hate is offline   Reply With Quote
Old 02-07-2018, 05:37 PM   #29
bmfm64
bmfm64's Avatar
Re: New brakes suck
I'm not positive, it was a 71/71 mc/prop valve.
Old 02-07-2018, 06:37 PM   #30
randy500
Re: New brakes suck
I could take a look at the brakes if you would like, Im in Tacoma. I have an adapter to pressure bleed, which is probably what you need done.
randy500 is offline   Reply With Quote
Old 02-07-2018, 08:16 PM   #31
Keystone_Hate
Re: New brakes suck
Normally, a 1" bore will give you more pressure and less volume. A 1 1/8" bore will give you more volume and less pressure. I don't know a whole lot about power brakes, but have you tried running an 1 1/8" bore master cylinder?
Old 02-08-2018, 10:31 AM   #32
bmfm64
bmfm64's Avatar
Re: New brakes suck
That would be awesome, can you PM me your contact info?
Old 02-08-2018, 10:32 AM   #33
bmfm64
bmfm64's Avatar
Re: New brakes suck
I have not- only 1" so far. but everyone I've talked to has said the pedal should still be stiff even with a smaller bore.
Old 02-08-2018, 10:38 AM   #34
Keystone_Hate
Re: New brakes suck
Ok. Just an idea. I had the same issues on my motorcycle. I was running a 9/16" MC to a four puck caliper and i could squeeze it all the way to the grip and it did almost nothing. I went to a 5/8" MC and it worked awesome. Just that little bit of extra fluid volume made all the difference in the world. I know it's not a truck brake system, but it operates on the same principal.
