#26 |
![]() Join Date: Apr 2016
Re: Slow Crank when Hot
Yes, true if you have a plain wire supplying full 12V to the distributor, to replace the original resistor wire. What do both sides of your positive battery cable look like, and both sides of the negative battery cable? Can you post pictures? I misdiagnosed a starter problem because of a bad battery cable on my truck last year. Other people on the thread have talked about their headers, but didn't ask you if you have headers.
#27 | |
And thanks for the recommendations! |
#28 |
![]() Join Date: Jan 2011
Does the truck have headers on it?
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#29 |
#30 | |
#31 |
Moderator
![]() Join Date: Jun 2017
Yep, not needed when HEI equipped...but make sure its not able to short out anywhere...tape off the end with electrical tape and secure it away from heat sources like headers etc.
#32 |
Moderator
Would suggest you replace the starter with a small format reduction style unit...new...not reman...
Grab a heat shield for it while you are ordering it... Even without headers, the exhaust pipe will likely be putting too much heat onto older fat style starter... Also...make sure there is a starter end support strap fitted and correctly in place... GM part number is GM 23502557...most wholesalers carry them...even Amazon... I have witnessed so many engine block damage scenarios with bolt holes stripped or broken out due to missing brackets... ![]() ![]() ![]() |
#33 | |
Something like this? http://www.jegs.com/i/JEGS-Performan...2/-1#reviewTab |
#34 |
Just a little different perspective on it. If the truck is cold, it has a good battery charge / New battery and you drive it for a while.. It's hot, obviously and you shut it off. This is when you experience the sluggish starts. .. If the truck is hot when you try to start it back up.
If the truck sits for a few hours and cools completely off, will it start back up normally? .. or are you saying at that point, even cold it won't start back up until you charge / replace the battery?
#35 |
Moderator
Yes Sir, that one will do fine...
on that Jegs page, also grab the heat wrap and the shim kit to correctly space pinion teeth from ring gear teeth. Also...make sure you use the correct knurled shank bolts to attach the starter to the engine. ![]() ![]() ![]() |
#36 |
Here is a link to my fight with this issue. I tried everything - long story short, nothing fixed it until I got a high torque mini starter.
http://67-72chevytrucks.com/vboard/s...d.php?t=729029 |
#37 |
landarts
![]() Join Date: May 2005
Had exactly the same problem you are having and did this to correct it. http://67-72chevytrucks.com/vboard/s...d.php?t=363603
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
#38 |
My truck had the same issue ended up putting a thicker gasket in between the carb and manifold and the problem went away.This is a common problem just on the edelbrocks.
#39 |
![]() Join Date: Dec 2013
Post a pic of your engine ,
Does it look like this http://67-72chevytrucks.com/vboard/s...d.php?t=509243 or this http://67-72chevytrucks.com/vboard/s...d.php?t=457938 It all makes a difference , next time you have a hard to crank issue use a set of jumper cables and hook them directly to the starter + post and a solid ground - next to the starter , get in turn the key and if it starts fine its your battery cables/ connections , If it still starts hard it's your starter is suffering heat sink . you can't ground your system to a valve cover . why jump to parts suppliers like jegs when anyone of your local auto parts stores carry exactly what you need just down the street ? personally I'd just go buy a new mini starter and a new set of good battery cables and be done with it , ![]() So many get hooked on setting up their 50 year old truck by the numbers the book say 8 degrees timing BUT it just may run better at 6 or 10 . these aren't computer driven systems . It's called tuning for a reason ... Last edited by Grumpy old man; 02-18-2018 at 10:57 AM. |
#40 |
I'd put the big ground cable directly on the block, not the alternator bracket.
What exactly is the voltage across the battery with the engine off and running? How many CCA is the battery rated at? I'd also be looking at the positive and negative cables and make sure they're in good shape. Grumpy's suggestion with the jumper cables is good, but the wording is a little funny. Connect from the + battery terminal to the big cable connector on the starter, then crank. Similarly, connect to the - terminal and to the starter body, then crank. |
#41 | |
1. Engine bay is dirty and original aside from HEI.. 2. Battery cables are like new. 3. Starter is a reman from Napa. 4. After replacing all of the ground straps and adding some more, I still have the same issue. Easy crank when cold. SLow crank when warm. I will try the jumper cable test. 5. Your point on timing is noted. In the past, I've noticed when it is advanced too much it doesn't turn as freely. |
#42 |
You've already had several tell you the same thing already, but I had exactly the same problem, went through all the same steps to make sure it wasn't something simple, and ended up purchasing and installing one of these. Starter from a 98 Tahoe. Problem solved.
1972 C30 Grain Hauler, 350/400 1967 1500 GMC Stepside SWB, In Transformation Process 1967 RS/SS Camaro 350/TKO600 |
#43 |
thanks. ive seen at least a dozen starter recommendations from reman to mini to Corvette.
