Old 03-23-2019, 05:39 PM   #26
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: LS Swap Crossmember choices
Very nice indeed! I'm doing my LS swap right now and using the PacificFab/Tilden 4X4 crossmember. Hopefully it works out OK. I installed a 2-1/2" Skyjacker lift a couple years back.
I like the differential cover you used on the front. I want to do the same on the front and rear of my Dana 44's. Who's cover did you use?
How did you make out with the transmission being cocked?
Did you go with Advanced Adapters for the transmission to NP205? I would love to see some pictures of the set up. I am using AA for my 4l60e / NP205 combo, but I'm not quite there yet. I know the 4l80 would be stronger, but for what I'm doing, the 4l60e should be fine.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 03-23-2019, 07:51 PM   #27
Blazerowner
Blazerowner's Avatar
The differential cover is a TA performance cover. I have them front and back. Nice covers and made in the USA. I will mention the bolts it came with did not fit. I had to cut them all because they were too long. Kind of odd thing. The rear is a 12 bolt not Dana 44.
Part number for the front is TA-1814.
I used an ORD adapter and they built me an np205 with the proper input for the 4l80. The 4l60 will be a piece of cake. It’s shorter and the crossmember has plenty of adjustment.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 03-23-2019, 09:06 PM   #28
renegade6
I used a square body cross-member and had to do a bit of surgery on it.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 03-27-2019, 03:49 PM   #29
webfoot
Where did you get the "dummy" block? I have a bare block for that purpose but that would be a ton easier since I could move it around myself. Does it have motor mount provisions?
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 03-29-2019, 10:49 PM   #30
Blazerowner
Picked it up from summit racing I believe. It’s a little pricey. I think about 400. It has all the bolt provisions that the real engine has so you can mock up headers, intake, etc. They make mock transmissions as well. It’s really light. About 25 lbs.
Kirk
Old 04-01-2019, 01:50 PM   #31
webfoot
That is pretty spendy. Sounds like the kind of thing it would be cool to rent or borrow.
-me
Old 04-01-2019, 04:44 PM   #32
Blazerowner
True. I just needed it once but I kept it in case I ever need again. I tried to find something local but no one had one.
Kirk
Old 01-11-2022, 02:36 PM   #33
hoist00
Going to bring this back up as I’m curious if there are any new alternatives to crossmembers? Looks like Tilden went out of business recently and Dirty Dingo has theirs on the sight but doesn’t list it for sale?
hoist00 is offline   Reply With Quote
Old 01-11-2022, 03:24 PM   #34
Richard
Here is the Pac Fab/Tilden crossmember.
Do not see any diference from the one I used.
http://www.pacificfabrication.com/ Looks like being sold as a weld together kit or un-powder coated. Do not know if this is a dead end as well, have not tried to call or contact.
Richard
Old 01-11-2022, 04:58 PM   #35
hoist00
Awesome, that must be the same Jason that worked for PAC Fab/Tilden on his own now. I still wish there were more options though.
Old 01-11-2022, 05:26 PM   #36
57taskforce
All about them K’s
57taskforce's Avatar
Here’s the welded version…
*edit link just goes to the same linked by Richard but if you click the arrows next to the pictures of the weld together kit it will bring up the pre welded kit.
Tyler
57taskforce is offline   Reply With Quote
Old 01-17-2022, 08:13 PM   #37
Blazerowner
I considered this one when I was doing my swap.
https://diy4x.com/product.php?produc...cat=252&page=1
Kirk
Old 01-19-2022, 06:23 PM   #38
hoist00
I don’t believe that one works with an LS swap
Old 01-19-2022, 08:17 PM   #39
52napco
I have a pacific fab cross member kit that I bought and not going to use if anyone needs one..
52napco is offline   Reply With Quote
Old 01-19-2022, 10:30 PM   #40
hoist00
How much and would you ship to Ca?
Old 02-25-2022, 07:52 PM   #41
Blazerowner
You might be right on that. It’s been so long since I did this. I wonder if you can just do some fab and make it work for the wider pan.
Kirk
