#26 | |
Re: Do factory truck small blocks usually come with steel cranks?
#27 | |
![]() I think I'll keep that one out of my vocabulary. I don't expect to use it.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-22-2018 at 09:35 AM. |
#28 |
![]() Join Date: May 2013
67 and earlier small journal cranks were all forged , after opening probably 50 68 plus sbc's 4 bolt and 2 bolt , ive yet to see a forged crank in the newer sbc's
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#29 | |
1) 67 and back 327s are all small journal and thus cannot be 4-bolt main. 2) 68 and up 327s are all large journal-however there are no 4-bolt blocks in 68. The 4-bolt block was introduced in 69. Mortec and others do not list a 4-bolt block in 68. 3) 68 is the last year for a 327 in a C10-30 so there are no 4-bolt mains in them since the block didn't exist yet. 4) as far as I can tell the only 327s in 69 went into Camaros and B-bodies, not into any trucks. C10-30 Trucks got 350s in 69. 5) Of course a 327 4-bolt can be made, but the factory never did.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#30 |
Opps , there was one I had ,, only one , it was a 70 lt1 motor that was in a 68 camaro I bought , ran like crap when I got it , heads were shot , exhaust seats sunk , I put 200 cc dart sportsman heads , and a 280 h cam in it , ran 12 flat with very little traction .
#31 | |
cast iron = more than 2% carbon
Stan 67 swb BLU MULE posted via flip-fone |
#32 |
Yeah, I'm not arguing anything. I can't argue on the 4-bolt thing because I truly can't recall at this point. It was an absolutely original '68 C/20 327 when I rebuilt it. It was certainly a forged crank in there. I was saying those articles never mentioned larger trucks is all. They did mention industrial, but the two aren't the same. So, are the block casting numbers for 302-327-350 that list as 2-bolt & 4-bolt mean 2-bolt at first, then came the 4-bolt in the same casting? I'm talking about 3932386 (68-74) and 3956618 (68-79).
#33 |
![]() Join Date: May 2012
Just update the history to show: 1970 K20 350 with a two bolt main. It threw a rod through the side of the block at under 80k. So what, plentiful and cheap to replace, even when I did this particular truck way back in the 80s.
My expectation on any engine in these old vehicles is... the lowest common denominator. Anything else is a plus. OP should not pull his pack and upgrade anything if it's running fine. I can't figure for the life of me why you care what crank it has, especially if a crate is being considered. Unless what crank you have is a deciding factor to keep your engine and work it. I think he should look at the crank and let us know. This thread has been an interesting read; a lot of fun engine trivia stuff. ![]() For the OP. I tend to work with what I got. If I want something specific in an engine, I go buy it. Rule of thumb... assume nothing! You've read the prose here. What crank do you have? Exactly!
White K20 |
#34 | |
http://www.mortec.com/castnum.htm and you will see for the 2 you mentioned 1968 is listed as 2-bolt and later applications are 2 or 4. There is enough meat to machine those (and 3970010) for either 2 or 4 bolt mains. As far as cranks, they are all over the place. Seems like early small journal 327s got a lot of forged cranks. Large journal cars and C10 seems to be mostly cast in my experience. The bigger trucks are where the forged 327 cranks came from. This is much less documented than the 2 or 4 bolt mains.
