#26 |
Re: PCM is not grounding fans properly
So then you're only going to run one fan speed?
#27 |
Yes. Instead of one kicking on at 195 and the other kicking on at 205 they will both kick on at 205. I suspect it will be fine. Is a manual tranny with no A/C.
1977 Chevy C10 SB, Turbo 5.3ls, TH400 |
#28 |
Same problem here. One fan works great 2nd fan pulses and relay clicks. 2000 5.3 4L60E swapped into a 72 C10. Don't have ac hooked up but that is why I bought a 2 fan set up. I will update post if I figure it out.
67 c20 68 c10 72 c10 69 GMC 72 short step |
#29 |
deleted response
1977 Chevy C10 SB, Turbo 5.3ls, TH400 Last edited by jrpontiac; 10-24-2018 at 02:20 PM. |
#30 |
See posts #21 and #23 in this thread on how to correct the issue in the tune file.
