04-26-2018, 11:16 AM | #26 |
Re: GMC Headlight Upgrade
You’re right, you could do the following:
LASFIT 9005 - Hi beam bulb Amazon price - $49.99 LASFIT 9006 - Lo beam bulb Amazon price - $49.99 LASFIT 9007 - Dual beam bulb Amazon price - $56.99 These are current Amazon prices. I bought the dual beam when they were on sale. Shop around on Amazon or wherever because you may find a cheaper price.
Customization is what you want it to look like -- not what other people think it should look like Last edited by EVRLET; 04-26-2018 at 11:52 AM. |
04-26-2018, 12:37 PM | #27 | |
The Halogen bulbs that go in reflector housings usually have a coating on the end of them so that the light is directed toward the back of the housing and reflected out of the housing in the correct pattern, so as not to blind those in the oncoming lanes. The projector housings have a lens in them that takes the light going forward (like from these bulbs or from HIDS) and then provides a cutoff so that the light only goes from the horizontal and down, and side to side. You will see a crisp horizontal line of the light. Otherwise, you are sending light everywhere and into the eyes of oncoming drivers!
1972 GMC 1500 Super Custom, 383 Stoker, TH350 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592157 Engine Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592233 |
04-26-2018, 01:30 PM | #28 | |
1968 GMC C2500 Long Bed Fleetside |
04-26-2018, 01:34 PM | #29 | |
I did a lot of research when I updated from halogen to HID on my VW, but already had projector housings in that car from the factory.
04-26-2018, 02:27 PM | #30 |
If the light pattern is what concerns some of you, they do have LED bulbs with the top cap to reduce the scattered light effect. But it’ll cost you a pretty penny.
http://www.xenondepot.com/h4-philips.../12953bwx2.htm There are mods you can do to any LED bulb without the cap to reduce the scattered effect in a reflector housing. https://www.tacomaworld.com/threads/...rd-mod.395222/ I have the relayed light setup in my 1997 Silverado and I will tell you that trying to compare LEDs to this type of setup is not a direct comparison. LED setups are for some and not for all.
Customization is what you want it to look like -- not what other people think it should look like |
04-26-2018, 03:06 PM | #31 |
I ordered lenses from a site called Daniel Stern or something like that. The lenses were approved by the European authority but not the DOT. The lenses were made with a sharp cutoff in the glass so that the light was directed properly and looked stock. I’ll see what I can find and post a link. I did this along with the relay upgrade and the difference was huge.
Here is a link to the website. It is pretty informative: http://www.danielsternlighting.com/p.../products.html Here is the headlamp I used: Last edited by Mike's money pit; 04-26-2018 at 03:11 PM. Reason: Added link |
04-26-2018, 04:07 PM | #32 | |
I can't comment on the Cibie's posted above, but I believe the Hella stuff is comparable, but may not be quite as good. The Hella beam pattern has a very sharp cut-off, dead spot for oncoming vehicles, and good ditch illumination. The high beams are very bright and have good throw distance. I can post pictures of how the Hella's look and illuminate if anyone is interested.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
04-26-2018, 04:23 PM | #33 |
I'd be interested in seeing that!
04-26-2018, 04:51 PM | #34 |
First image: left beam is Hella replacement, right is standard
Second: beam pattern on a building Third: Hella low and high beam installed Next time I'm out at night, I take a couple pictures down the road comparing the difference between low and high beam.
04-26-2018, 05:11 PM | #35 |
Been installing Hellas since the 70’s....
71 C-20 07 Magnum RT AWD |
04-26-2018, 06:16 PM | #36 |
Those look really good. I'd like to see those pictures. Thanks!
04-26-2018, 08:33 PM | #37 | |
20' Daredevil (Ret)
05-02-2018, 02:15 AM | #38 | |
Second picture is the high beam The red dot in the middle of the picture was a windshield reflection of an interior light. Both pictures are taken with the same shutter speed, aperature and iso to avoid any adjustment made by the camera. The brightness of the near areas in the low beam picture sort of wash out what you can see at a slightly longer distance, but it is still an accurate representation of the beam pattern and throw distance.
