02-20-2021, 04:39 AM | #26 |
Re: Changing from a Low Hump to a High Hump
Book marking just for the vendor info.
I will be adding holes in the firewall, and add plugs, while there to get to the upper bolts of the transmission bell housing. So if the Transmission needs to be pulled ) in my case most likely will be in and out a bunch) It just be a matter of pull the 4 grommit plugs . and socket and ex. to get to the bolts. Getting to them when vehicles are on stands is a pain. this will make it simple. and might as well add them while there adding the hump. Making swapping/testing converters at the track a lot easier. |
02-20-2021, 12:58 PM | #27 |
Good information I will be cutting mine out to.
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
08-01-2022, 01:00 PM | #28 | |
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
08-01-2022, 01:36 PM | #29 | |
08-01-2022, 04:10 PM | #30 |
Just noticed this one, I know it's an older post but just adding to Dads comments.
This truck had quite a few modifications to the Kmember, engine mounts, etc. It was done before I bought it. The engine had been moved back from the factory location (Big Block, or small block) to help keep it from plowing in the corners. With the BBC setup it was done this way to keep it from being nose heavy. It definitely wasn't in the stock Fore/ Aft position. I understand it can be done with a low hump. Just saying, in this truck, in this position we had to do a high hump to get it to clear. Just wanted to clarify. Pop was really just trying to document how it's done, where to cut, how we did it, etc. Not saying you need a high hump if you have a TH400.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
08-01-2022, 04:19 PM | #31 |
08-01-2022, 05:28 PM | #32 |
08-02-2022, 07:31 PM | #33 |
Maybe this is getting a little off track but since you brought it up I will report that my 1970 GMC2500 3/4 came stock with the TH400 and a low hump. I had to double check since I recently purchased carpet and had to get the hump right
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. |
08-03-2022, 10:25 PM | #34 |
I have a ‘69 C2500 parts truck with a first year small block 350 and TH400 and its a high hump. All the big block trucks I have owned have been high hump. Same with SM465.
