04-29-2018, 01:46 PM | #26 |
Re: Battery location
behind the pass seat in truk since 2010, no box, no vent, just the battery
the cover with the finger hole, cover held in place with velcro just swapped out the battery 2 weeks ago, easy to get to
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-29-2018, 02:40 PM | #27 |
Thanks guys, I've got some food for thought. I think I was also overthinking if the battery needed to be protected from water and road debris. Mine looks like a hacked up version of Black Sheeps. If I go factory spot route, I'll need to make of buy a new shelf.
1950 Build |
05-18-2018, 11:31 PM | #28 |
I was going to put it behind the seat but opted to mount it to the firewall.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
05-19-2018, 01:14 PM | #29 |
ironic that the AD guys move them under the hood and the TF guys move them out from under the hood
05-19-2018, 01:52 PM | #30 | |
I like them under the hood, big cables and connectors can be a big expense.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
05-19-2018, 02:19 PM | #31 |
I'm not very picky on location. Under hood seems more convenient.... my concerns were how to carpet floor and still use factory spot, or how to put under hood and be able to install ac/heater too.
I had thought of the wires and connectors... is there that much of a cost difference between under hood, in cab, or under cab?
1950 Build |
05-20-2018, 01:05 PM | #32 |
no pic but i am doing a 55 2 chevy with a duramax with 2 batteries they are side by side inside the frame and can be removed from under the truck. They are at the tail end of the trans, and under the cab
05-21-2018, 06:40 PM | #33 | |
05-22-2018, 11:06 PM | #34 |
No dif in cable. AD bat is very close to the starter, no need for longer cable.
05-24-2018, 09:57 PM | #35 | |
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
