Old 07-10-2018, 11:40 AM   #26
Roadkill58
Roadkill58's Avatar
Re: 1959 duel master cylinder with power booster
I'm running a muncie 4 speed trans. I moved my master cylinder / booster under the bed behind the cab. The bed floor is raised 4 1/2".
Rust Never Sleeps
Roadkill's 58 Chevy Stepside build
Roadkill's 69 Custom C20
Roadkill58 is offline   Reply With Quote
Old 07-15-2018, 09:32 PM   #27
2001convertable
Got the unit in and plumbed in as well. Special thanks to Sack54. I drove this guy crazy. Thanks Tom
2001convertable is offline   Reply With Quote
Old 07-17-2018, 04:08 PM   #28
sack54
looks good . Next you will need old time remote brake fluid reservoir ,or pain trying to fill.. I found some good ones i'll send you the site. Always willing to help out.
sack54 is offline   Reply With Quote
Old 07-17-2018, 06:00 PM   #29
SanJosesSteve
SanJosesSteve's Avatar
I replaced the stock single chamber MC on my 1959 with a dual chamber model with no booster. (Filled with DOT 4 and added the 2 in-line pressure differential valves too.) I kept my drum brakes on all 4 corners. With properly adjusted drums, the pedal is high, the response immediate, and the pedal effort not bad at all.
I read an article about old hot rod guys drilling their drums for additional cooling. I had mine done. Not sure if I notice a difference, but several times now I have driven it loaded down a 10,000’ mountain pass w/o issue. -Steve
"What's that round short pedal on the floor do?"
SanJosesSteve is offline   Reply With Quote
Old 07-18-2018, 08:48 PM   #30
2001convertable
Did you need the pressure differential valves? Can I use Dot 3? I didn't finish yet. Ran out of time and worked overtime all week. I have to finish on Saturday I have to adjust the play in the linkage and Bleed and check for leaks.
