07-11-2018, 11:06 AM | #26 | |
Re: Help! need steering box for '67 C10
Good luck in your scrap yard hunting, just don't take that P/S changeover unless Smitty does not want it. Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
07-24-2018, 10:00 AM | #27 |
Sorry, but no junk stuff in my truck. Purchased a brand new box from a great outfit in Washington called Red Head. They shipped the unit in a well-packed box designed for me to return my old unit. The new steering gear box works smooth as butter.....so smooth in fact, that I may decide to add a damper to allow for more "road feel." I highly recommend Red Head. BTW, they paid for the return postage ($60 at UPS) and credited my card account for $150 for the returned core. Great company to do business with. They rebuild nothing but steering gear boxes and give advice over the phone.
07-24-2018, 10:02 AM | #28 | |
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
07-24-2018, 11:46 AM | #29 |
Anyone use the CPP "500" series box? $375 without a core. It has a sexy billet cover on it also. I have used an Autozone rebuilt special in the past and it was very smooth but had zero road feel. I don't want that for my current build.
http://www.classicperform.com/NewPro.../Series500.htm |
07-24-2018, 01:23 PM | #30 |
Not familiar with the CPP box, but feeling that a steering damper might give more road "feel," can anyone recommend a quality steering damper that will fit on a stock '67 front end? I have all the catalogs, but don't want to get stuck with something that doesn't work well from a company that is now well-regarded.
Any suggestions will be appreciated. |
07-24-2018, 05:42 PM | #31 | |
72 C10 lwb fleetside -stock 350/350 combo |
07-25-2018, 08:40 AM | #32 |
Get a box from a 78 c10 , its quicker ratio , and has valving to firm the wheel at center , or when going straight down the road , an excellent upgrade for almost $0 , if you don't trust a used box , get a rebuilt and turn your old box in for a core . make sure you have a sway bar up front also , many came without them
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
07-25-2018, 09:59 AM | #33 | |
07-25-2018, 10:38 AM | #34 |
The majority of 67s frames are not dimpled to fit the power , but some are , its and easy modification to heat and hammer , I would not use spacers
07-25-2018, 12:34 PM | #35 |
I used the cpp box. I do not recommend it. I used the spacers for my 67. I have a lot of hard spots while steering. Don’t waste your money. A believe a later square body box is the exact same thing.
07-25-2018, 10:17 PM | #36 |
My 68, which was built in the fall of 67 was not dimpled from the factory. I had to dimple it to install a power steering box.
1968 SWB Step Side, Big Block, 4L80E , Running! |
04-17-2020, 10:31 PM | #37 |
Bringing this back from the dead to ask: does anyone have a pic of the 67 frame before and after being dimpled?
I’ve got a ton of slop in my steering box and need to do something about it sooner than later. |
04-18-2020, 12:04 AM | #38 | |
The Older Generation
Post #4 in this thread shows a '67 frame that is not dimpled and post #8 shows a later one that is. http://67-72chevytrucks.com/vboard/s...d.php?t=804452 The original poster in that thread used a new CPP steering box and evidently you don't have to dimple the frame with those. LockDoc
04-18-2020, 12:07 PM | #39 |
I bought a 1969 up C10 Saginaw power steering box, and hammered the frame between the bolt holes until the bolt flanges touched without the center of the box touching the frame.
04-18-2020, 12:50 PM | #40 |
Before you decide on what you do, see how the one in your truck now is mounted.. chances are there are 1/4 inch spacers on each bolt. If so, more then likely they used a ps gear from a square body like most of us do. If you post a pic of what's in the truck now that would tell us wonders and give a better idea of what to purchase
1967custom |
04-18-2020, 01:20 PM | #41 |
Thanks Leon. Appreciate the assist.
Here's the steering wheel play. https://youtu.be/uFt3FwPVYfU Steering box post to follow. Also, I just realized I've got a 68 parts truck and the steering box seems pretty tight. I think I'm going to yank it, clean it up, then get it installed in my 67. Thoughts? |
04-18-2020, 07:42 PM | #42 | |
Yeah, that looks like quite a bit. If it had the full size wheel on it it would be a LOT..... No reason you couldn't use the '68 box. Just check the fit against the frame. LockDoc
04-18-2020, 08:38 PM | #43 |
Didn't quite pickup on what was causing play. You know that there is an adjustment on top of the box that will reduce play?
04-18-2020, 09:04 PM | #44 | |
If there's an Adjuster, I'll definitely give it a try, but it's leaking power steering fluid form somewhere, so I've got to dig in anyway. |
04-19-2020, 11:12 AM | #45 | |
If you tighten it up too much, when you turn a corner you won't be able to straighten it up and you will drive through a fence and almost hit a tree... Ask me how I know..... (on second thought, don't) All I know is you want to loosen the lock nut and only turn the adjusting screw about 1/8 of an inch at a time then re-tighten it and try it.... Also remember where you started. (mark it) Normal disclaimer applies. Do this at your own risk. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-20-2020 at 09:56 AM. |
04-19-2020, 10:12 PM | #46 | |
https://shop.advanceautoparts.com/p/...chTerm=27-7501 https://shop.advanceautoparts.com/p/...Term=lares+201
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 04-19-2020 at 10:19 PM. |
04-19-2020, 10:55 PM | #47 |
Lockdoc was very correct in that you don't turn it much. I was adjusting box on daughters 03 Rubicon to reduce play. Loosened lock nut and figured righty tighty - gave it a turn and locked it down. Turned steering wheel to try and it went a good 90 degrees. Looked at output shaft and it had moved down out of box by noticing shiny shaft. I used crocus cloth to clean shaft so that when I turned adjustment to eliminated play it would go back up into box without messing up seal
04-19-2020, 10:57 PM | #48 |
Lares sales an all new, not rebuilt QR box. I bought one for my 67. The lares boxes were quite popular on a square body LS swap forum I'm on. The 67-72 P/N is Lares 11075 at Rock Auto. No core. $335
https://www.rockauto.com/en/catalog/...ring+gear,7416
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
